Goat Herder
Gutter Rider
Wow that's off by a lot
Wow that's off by a lot![]()
mapbike,
I think you are right. I already noticed the big end needle bearing just has loose rollers, with no cage, just like you describe. From what little I can see, I was thinking it looked like there aren't enough rollers. I don't think I lost any yet, but the way it sounded when I turned it off, it was ready to start spiting rollers any minute. There seems to be a lot of play in the big end now. That's probably the only thing wrong. The crank being out of balance is probably normal.
Yep I agree on all points, I would replace the crank roller bearings with quality 202 units and then I would get a new crankshaft assembly and use a quality upper bearing, then you'll have something that should last you a good while.
Here's best deal I've found on a new crank.
bicycle Motorized BIKE ENGINE parts 66 70cc cc crank | eBay
Peace, map
Why does this not surprise me?
If this is what the outside looks like, who knows what the inside looks like.
I like the fact it has a quiet muffler, I'm trying to figure out a way to make mine quieter. I was thinking of putting steel muffler stuffing on one of the chambers inside my muffler. Of course I don't want too much restriction causing my engine to over heat. What do you guys think?
Do I put a bigger jet?
This sounds like a down grade mod, I don't think I want my bike to perform less than current. Thanks for your input.I have an x80chrome.runs very well,smooth,easy start.so far no probs.ps, the PK in pk80 stands for power king.Good luck rebuilding that thing!
I got it from lucky early bird probably about a year ago.I dont remember the factory name.but its the x80 68.5cc with the bent clutch arm.Sounds like your a better machanic than me.I just install them and baby them through the breakin and fine tune them(adjust carb and clutch,etc) as best I can.so far I have only removed the head.never took one completely apart.I have 4 bikes with these type motors on them.They are all different brands 66cc kits.plus I have sold 2 and given away 1.so I have had 7 of these kits,all different.for the price they are all pretty good but I would say the skyhawk gt5 and the zb special edition are the best quality.At this point my gt5 is broken in and running swell.
Biknut, I'm glad you figured out the issues, so the solution is to replace it with a true crankshaft? Do you still have the exhaust that came with this engine? Wanna trade? I have a chrome one that is in great condition.
