I'm sorry to have to report that after 3 months and about 550 miles this X80A motor has failed. What a pity too, because it was a strong runner.
I was riding night last when a nasty noise started coming out of the motor. I was just doing easy cruising at the time. I think the crank bearing has failed, but won't know for sure till I get inside it. Nothing dramatic happened, it just started making a loud scraping sound. I rode it 2 miles home under power after it happened. It still had good power.
I'm thinking something may have been wrong all along, because this motor always made a lot of squaking noise at about 5,500 rpm but sounded ok below that. It's been a concern from the start.
So far all I've done is remove the primary cover, and spark plug. When I turn the motor over, I can see the pinion gear looks like it's wobbleing around. Looks like the crankshaft could be bent or something, but I'm not sure how that could have happened. Maybe from someone installing the pinion gear with a hammer lol. A sound is coming out of the spark plug hole that sounds like the piston might be contacting the head now too.
I'm going to try to rebuild.
Keep us in the loop man. Especially if you have trouble finding parts.
