cobrafreak
If you are using a Comet series 30 Torque Verter Transmission put an Odometer on your bike and keep track of maintenance. The rear jack shaft bearings on mine destroyed themselves yesterday. I had to call AAA for a ride home. No other damage happened. I had 1400 miles on those bearings when they blew. I recommend replacement of them around 1200 miles. They won't last forever. Motion Industries, a bearing supply house that is Nation wide has a good replacement, #00106201, it is a precision ground made in America bearing for $16.92 each, and you will need two of them. I should have thought about this first. It's the fastest moving bearing on the bike next to the engine and it is permanently sealed, so you can't re-lube it. Cheap insurance from getting stranded.
