Helen Weals
Is it possible to Increase the stroke on these motors? Is there enough "meat" on the flywheel to offset The crankpin, use an offset crankpin ,or can it even be done on a 2 smoker without effecting the timing?
This supposedly helps you change timing:
There was a member once, a long time ago, who stroked the flywheels by Tig welding the crank pin hole up and machining the hole closer to the edge of the flywheels. He also ran a moped piston, cylinder and head. It was quite a Frankenstein sort of engine, and extremely fast.
He is no longer a member here though, and I cannot find any threads concerning it.
Like I said, it was a looooong time ago.
