kevyleven007
yeah that should work.It really is a nice looking bike.It says on the WM site it is no longer available online so looks like it might be hard to find.
you should be able to get a sprocket from kings.If the tires are too wide for the chain to clear you could switch to 28" or 700c tires they all use the same size rims.fyi 700c.28".29"tires all use the same size rim.good luck
A simple solution for better stopping power would be mounting adapter plates and a set of v-brakes fore and aft. You could mount both (front and rear) for under $99.
ijust got fin ish last night the 29er crusier from wallmart its a sweet build my first one to build took me a while to get it together had to order front engine bracet for large tube back wheel went togeter it can be done i did not have that much trouble i did it wit what come wit the kit it worked fine i road it last night it road so sweet on vribation at all runs like bat out of **** its just got a 48cc gt2b on it i pulled a steep hill it will run at lest 25mph its very smo oth im going to put a 80cc on it ill help anyone who needs help doing one it is a sweet buildjust saw a 29 cruiser at wally world and it look sweet only 149.00 might be a cool build
