Terry Blow
Dealer & Custom Builder
Got out yesterday morning before the temperature dropped and the rain moved in. Got 40 miles in between 3 towns in the Twin Falls area in a 2.5 hour time frame. Had to get a time frame of the travel time for work.
The first town was 8 miles out on fairly level ground and hit 25-26 MPH on the way into town. Heading to the second town...drove down the major highway with hills all the way. (Thought my legs would fall off.)
On the way back to my home...took another way home along some back roads. This trip was fairly level and had my speedo up to 31 MPH and 27-29 MPH for about 8 miles with barely needing to open it up. Seemed the HS had more power than I was expecting...with my butt and arms feel like getting the workout from that much mileage.
Do have two questions. I'm using a 44 spoke rear sprocket that was used on my 2-stroke last year. If I head up to a bigger sprocket to not wear out my legs on the hills around here...what size would everyone recommend/where would I get it from someone who might have it available? The more miles I put on the HS (keeping the oil changed)...will I get more power?
The funniest part about the trips yesterday was the station attendant asking where I was going to put the $1 of gas. She was amazed when I showed her when I got my .07 in change.
This is not my thread to barge in on but it depends on many things. First thing is what kit are you using and your weight your bikes weight and your area. If it is hilly or flat but most important if you have a qmatic you should be using 56 tooth or bigger
Sorry flex man.
