Headset & bar modification
Jemma Hawtrey
Hi,
I've made a major change to the bike today. Basically I have reversed the headset on the bike and redone all the controls to suit.
The only problem I have run into with this setup is knees and handlebars when pedalling slowly (from stop), they tend to collide... :-{ and manuvering the bike is harder because the end of the bars hit my legs - this should be solved by moving the seat back further (which means a new seatpost :( )
I've also moved the storage bag I had on the bars to the RHS of the bike using the GEBE mount to put it on the bike. I *might* be able to fit another bag on the other side.
My fuel tank is leaking slightly from the top bolt mounting on the RHS of the fuel tank but I cant see a leak anywhere - is there anything I can use to stop it?
Comfortable cruise is now 31mph and the bike will wind out another 4-5mph above that WOT.
Pictures are attached
Jemma xx
Why did you do this?
Because it saves me back and shoulder ache.. I have tendonitis and a spinal injury so I get pain after about 10-15 minutes riding in my shoulders and upper back.
The headset isnt long enough by a couple of cms - when I pedal I can only do it in a straight line.. but then I am using the bike 100% engine at the moment so its not so much of a problem. I get enough exercise walking and such :)
Regards how high the thing is - its around the highest extension mark and I have been careful to look at it to make sure it isnt twisting or anything.
It has affected handling - it seems to have made the steering more responsive.. I just wish I could get a longer headset.
Jemma xx
Jemma,
I'm in the same boat with the severe back problems, so on my current build used some mid-rise handlebars with a high angle stem. I'd second a higher handlebar approach. Stems are pretty cheap as well and you should be able to find one that will put the handlebar base a little further from your legs but give you a much more upright seating position.
I had to build mine so that I had a completely upright seating position due to my back:
Here are a couple of ideas:
one of these:
KALLOY TRI/MTN QUILL STEM - 1" at JensonUSA.com
With one of these higher rise cruiser bars.. this set has a 126 mm rise.
DIMENSION SUPER WIDE CRUISER HANDLEBAR at JensonUSA.com
What is the rise on your current handlebars?
Jemma,
one of these:
So far as I can tell they are flat bars - no rise at all. The effect I was going for was the '00's style motorcycle look. Then having put it all back together I find out that its soooo much more comfortable to ride..
Had a guy come chat to me today - im riding a GEBE and hes riding a Moto Guzzi twin of some description.
I might try inverting the bar and see if that improves the clearance thing.
Jemma xx
I really want to do the same thing. I have a North Woods Ridge Dale Cruiser, and the stock stem shaft diameter measures 25.mm. This dimension quill stem adapter looks good, but wouldn't it be a little too sloppy inside the fork tube? I tried using an old dyno bmx stem(21.1mm) and that's just way too small. The reason why I want to change out my stem is because this odd looking pinch bolt is only torqued to 4 ft lbs, and it says NOT to torque it any more. It is covered by a cap, and even has a little yellow warning sticker on it. The damn thing has a lot of flex in it, and I want to eliminate that before I motorize my bike. Any input would be greatly appreciated. thanks.
I might turn mine around too. Right now im using wide cruiser handle bars but i get the bike stuck when bringing it threw my doorways inside my apartment. I have some straight bars i want to use but they would be too far forward for me to reach since i like to ride leaning back and not hunched over forward, so i may turn the stem around to bring the handle bars closer to me.
