104 mph self peddled bicycle
thine82
i have been working on a projext that will allow average people to go atleast 72 mph. yeah thats right.... on just peddling. no motors. although dont get me wrong i will always rather have my motored bike. i hate peddling at all. but what could the law do if i get to produce this application for bikes? all you gear heads or people that build real parts and peices... i need you to fabricate some stuff for me so i can build this thing. ofcourse i will pay and if you do it for the right price then i would either give you one of these bicycles or have you help share the wealth by making partners so you can always have the sole right to fabricating this application.
my idea .. i get most the money.. your time and work.. you get your honest dollars living ... or new awesome career..
just a dream i have been working on and if it works .. then cars can say good night .. ahh maybe not who wants to peddle across the damn state or a the country..lol....crt.dance1.we.
if you have questions then ask...
i am currently trying to find people or the parts to put this thing together. i have the math all worked out. just need the peices now..
because you guys are awesome i will fill you in quickly.. i always have these random ideas..lol... well i thought how about it.. and i did some looking and found that wind mills use a change over process that makes 30 to 40 rpms to about 1500 rpms. so i started looking it up and did the math.. i belive it will have to be 44 teeth to three teeth.. or 44 to nine.. but there is basically five drive sprockets and yes the back tire counts as one kinda.. i will have to load some pics or posts of the pages that i did my research on. but i want someone to be able to build a cassette crank that goes from smaller to bigger .. then into the gearbox or transmission.. dont know what it would be .. then build the box with all the stuff in it .. once sent to the back wheel which might need a different cassette also on it.. i am unsure of that as of now. the regular gearing would still be on the mountain bike in the new cassettes so you could get rolling then as you start moving is when you could change to the other gears so it would haul azz... i talked to a few people and they said it is very possiable.. what do you guys think? just a tinkering idea once again cuz i dont have the means to build this stuff.. well i could order and pay ALOT to do it but i dont wanna do that just yet..
how could you get more horse power out of your legs when it is based on a 30 rpm? cogi..
scotto ..
have you tried to figure this out and thats why you said a 70 tooth chain ring?
http://www.windmission.dk/workshop/BonusTUrbine.pdf
page thirteen explains how it kinda has to go on.. and then...
Magnetic Induction Bike Lights (Mod)
No I haven't tried figuring it out because I'm not really interested in trying to pedal that fast or even attain those speeds on my motorized bicycles. I can tell you I've done 62mph riding down the road from Convict Lake on my mtn. bike with a 52tooth front chainring and 10tooth rear. This was in mild prep for running the Kamakazi Downhill at Mammoth Mountain at the Norba Finals in 1990. I think John Tomac who won it that year was running a 61tooth front chainring so I just figure a 70tooth front could get you a fairly high top speed............on a DOWNHILL! That's all.
Oh i gotta see this, show us your 'math' seeing your being so open about it all...
I'm sure the faired recumbent riders would love to se it too seing they can't get past 85mph with all their aero aids and muscle power.
KiM
The only math I am interested in seeing is:
The calculated drag coficeiants at 104mph. (using an upright or recumbent (?)
You cant fool the laws of fluid dynamics.....
the gearing ratios are the easy part.
good luck....google Sam Whittingham. for a little help.
I think Thuds your man hes good at building boxes with stuff in it. (wheres the tongue sticking out emotion dammit... :-P )
Quoted from here: Human Powered
Pedal power uses the most powerful muscles in the body: the quads, hamstrings, and calves. When pedaling in a circular motion at sixty to eighty revolutions per minute, with the use of toe clips, almost every muscle in the human legs can be used to make energy. Ninety-five percent of the exertion put into pedal power is converted into energy. The average rider at a continuous road speed of twelve miles per hour can produce a quarter horsepower (Wilson 1977).
The average, fit, adult rider can produce only 1/10hp when cycling at a continuous 12mph.
Only a top cycling athlete can produce about 1/4 hp - and this is
only for short bursts before overheating - not continuously
, and this was confirmed during the Man Powered flights for the Kremer challenge in about 1981.
" I too have read "Bicycling Science" by Wilson 1977, and I think that someone has perhaps mistaken continuous power with peak power. At the end of the day we are just machines, and if you stress us too much we will break sooner."
Ken Boak <kenboak@stirlingservice.freeserve.co.uk>
Well, start with a NuVinci N360 shifting hub.
Product Description
NuVinci Internally Geared Hubs
* CVP (Continuously Variable Planetary) drivetrain technology with an infinite number of ratios
* Simple twist controller enables easy, continuous ratio adjustments while pedaling
* No missed gears, hesitation or noise
* Includes CruiseController shifter
* Comes disc ready, Roller cam adapter available as spare part.
* Recommended gear ratio is 2 to 1 (ex. 36/18)
* Freewheel not included
* Hub's shift drive fits behind dropout for clean installation
* Shifter's cable has quick clip on and off system to allow for simple flat repair
Item Specifications
Weight 2450g (5.4 pounds)
Intended Use Road
Hub Drilling 32spokes
Rear Axle Type 10x1
Cassette Body Type Threaded, Standard
Hub/Brake Compatibility 6-Bolt Disc
Rear Hub Spacing 135mm
Ratio Range 360% Nominal
(0.5 Underdrive to 1.8 Overdrive)
Shifting Variable Twist Grip, 3/4 Turn
Sprockets 17-22 Tooth Supported (standard 9-spline, not included)
Sprocket Ratio 1.8:1 Minimum (17/31, 18/33, 19/35, 20/36, 21/38, 2/40, larger chainrings can be used without exception)
~$360.
At least that way you still use 100% of the input power even while shifting.
Then slap on a front derailer with 3 huge chainrings.
Regardless though, a 1/4 HP in short max pedal bursts isn't going to propel a wheeled vehicle with a human at the speeds you are talking on this planet I don't think ;-}
I forgot too mention, there is not or ever will be a 3 tooth bicycle sprocket, the smallest I know of is 8 tooth. And a 70t front chainring would prolly be scraping the ground. Conventional bicycle chains and gearing will not get you there (72-104mph) without a 90 degree descent.
guys check out my profile pics.. i am still think about this gear box though..thanks for the info but my math is with a stock 44 tooth to start with so i dont have to change that sprocket hopefully
The one with stuff in it? can you elaborate on what stuff is in it please, this will allow ThudSTeR time to order in necessary components, if of course you decided he is the one you commission to build the gearbox, with stuff in it...
Might also be useful if we could be let in on the "math" that will get this beast of a bicycle to 104mph, seeing nobody else in the world has managed to do it on flat ground with pedal power alone, until now of course if only theoretically with your numbers and design... Wish you well in your endeavor ** subscribed**
KiM
p.s Can you hear that sound Thud? that's the breaking of world records buddy ...:: crosses fingers:: you get the job building this gearbox with stuff in it ;-P
Did you hear that loud boom when that bike passed a few seconds ago,,,,
Gearing for a high speed is a reasonable goal ,but now we need the HP TO TURN THE FIRST GEAR IN THE SET
what is that stuck in the side of that truck???lol
Just assumed it was thine82 hamstrings letting go from the bone as he pushed the bike to 104mph :-|
KiM
EDiT: while you recover from this minor setback thine82, we had an idea, well actually i must give credit to ThudSTeR :-P ... perpetual motion overdrive for the gearbox with stuff in it!! what ya think? thine82 I mean, heck! why stop at just doing 104mph?!?! Lets smash those pesky laws of thermodynamics once and for all thine82
kim your too funny and one of the reasons society can not advance that fast... if i told you i had a working magenetic motor that makes power and does not use power except the magnets you would laugh also..
cogi your awesome.. to get to the heavey great gear.. well we would need a different cassette built for the front of the bike and a shifter to go through the gears.. the gear ratio works from two shafts that have the sprockets on them.. 1 to five ratio.. every one peddle .. the other gear turns five times.. then the next chain to the sprocket bar would be the same ratio.. then it would go to the back wheel.. i did do my research.. anyone see my profile pics of my new gas tank cover yet? i made a fiberglass one
