49cc/52cc Scooter Engine with Electric Start - EPA Certified
More of the "pocketbike" type engines, new, without the bike.
wonder if the starting wires act as a generator when the motor is running?49cc/52cc Scooter Engine with Electric Start - EPA Certified
Easiest mounting suggestions:Anyone have any mounting ideas for a pocket bike engine?
Thanks
Sam
Very cool 5-7Heaven, thank you. I too thought they were wider. Got my next project in mind now.According to info available, the Honda GX50 is 10.8" long, 7.7" wide(pullstarter to bellhousing) and 13.9" tall. It weighs 12.1 lbs.
My Mitsubishi TLE43cc engine is 9.625" long, 6.75" wide and 10.25" tall. According to my bathroom scale, it weighs 9.4 lbs.
My GP460 engine is 7.25" long from carb to exhaust port, 7.25" wide and 8.25" tall. It weighs less than 7 lbs(estimated).
My pocketbike engine is 9" long, 6.75" WIDE and 4.75" TALL!!! It weighs 7.8 lbs.
The 460 and pocketbike engines are even smaller in mass/dimensions than Honda/Mits engines. This is because H/M engines are boxy; pocketbike/460 engines lack massive plastic carb and exhaust covers.
Pocketbike engine is VERY short. You could stack TWO Cag engines in the space of a Mits engine, and almost THREE pocketbike engines in the space of a Honda GX50 engine!!!
So the misconception of wide pocketbike engines are grossly untrue!
The 3:1 pocketbike transmission which widens the engine is not needed, when used in conventional engine drives. If frame-mounting the pocketbike engine with this 3:1 gearbox, a 9:1 jackshaft will be needed to transport power to the cassette/shift kit.
The 5:1 pocketbike gearbox can be utilized, placing the engine sprocket in correct position, without using jackshafts. A 28.6:1 gear ratio is easily attained by using 11-tooth gearbox sprocket and 63t drivering sprocket.
JMO, mounting a pocketbike engine with a Scooterguy mount and a mix of pocketbike sprockets and SBP components would be a compact and powerful combination.
I might do that.
Good engine, yes?hi !
my 26" mountainbike with home made rear rack & rear rack mounted 47cc cag engine is atm waiting for exhaust to arrive from UK. i have some messages regarding it on other topic: "front mounted minimoto engine" that is relatively silent but with man named Jose with lill simular set-up on rear rack with Youtube video on the topic..
This bicycle of mine has all the original gears in function and usable by human power pedalling..
btw, does any1 happen to have 4sale the plastic part and pressure spring that sits in middle and inside the PullStart Cog/pawl ? These mentioned 2 parts seems to be uber difficult to find, Ebay's are useless etc.
only upgrades to engine parts so far are Dellorto PHBG19ds copy carb + manifold and exhaust will be this kinda http://www.jonny69.co.uk/uploads/bikes/mini moto/IMG_3508.JPG
Also i will try a longer sparg plug to gain some compression and smaller head volume.
Later i shall "dremel" do some transfer/canal to the std 47cc cylinder, like 49cc ones have...
Does some1 happen to know if the 1st curve pipeing goes further inside the Chamber ? ive heard that some do...Mine is exactly same exhaust model as in the piccy exept that the visible straight pipe b4 chamber on mine is like 5cm shorter or summink.
Mostly im doing this bike project from Scrap yard/Recycling center parts.
for example Throttle grip i will try and make from a bicycles gear change grip, this kinda idea of part to use: http://www.shreekumar.in/pics/viper/frontgripshift.jpg
bye
m
Do you have a pic of these parts? Does the pullstarter have the white plastic bow-tie config? I may have what your looking for.hi !
bye
m
Do y'all use those gizmos that generate while braking? I guess with one of those you could go forever if it was downhill all the way.
Seriously though, those uh, what is it, a super charge controller that reverses and charges using the motor for dynamic braking? That would probably only help in city stop and go but every little bit helps. Solar panels are getting smaller and smaller, too. Not much current but, again, every little bit.
Is ICE a gas engine/alternator to battery to motor drive? Do you use a fairing on your bike? The other aero stuff?
Has anyone down there tried making their own wheel motors/alternators using (if you can get enough) rare earth magnets scavenged from dead computer hard disks?
Dang I'm out of coffee.
Ted
