well i took the cylinder sleeve off the motor to "dress the ports" with the new dremel that I got yesterday. sadly i made a big NOOB mistake and when I put the cylinder sleeve back on it wouldnt go on all the way....so me being who I am and relatively inexperienced took a block of wood and a small hammer to the top of it to "nudge" the thing back over the piston. I didnt even think to check the piston rings . i didnt notice until i tried to ride the thing to work and i couldnt get the thing to start. I had to disconnect the chain and pedal the 4.75 miles to work....
....luckily i left 45 minutes early so i was still on time. i took the motor apart at work and plicketty plack the piston rings are in a million peices and unsalvageable. for future refrence anyone who wants to take the top end of the motor apart BEWARE the piston rings. Just make sure that you pay attention when you are putting it back together to compress the rings before trying to put the piston back in the sleeve. and dont use a hammer and block of wood to "tap it back together" it should go together as easily as it came apart. luckily the wall of the cylinder isnt marred up so I go on the hunt for new piston rings today. hopefully an auto parts store will have some and its a long weekend off work for me if none do. just be careful and pay attention when taking the cylinder sleeve off and putting it back together.
Or use Lee "press-on" nails?
Avoid hoseclamps!
