Adjust your band brake. The brake drum seats against the sprocket on the fixed version. If its froze up as you say, then the band brake is too tight. Adjust the line to your handle, then adjust the brass nipple on the brake cover till you get it just right. Good luck.
So the entire wheel is not turning? Hmm. Can you take some picts of how the wheel is mounted? Also make sure the brake cover is not touching the sprocket, since it remains still while the brake sprocket and wheel spin together. It could be locking it up.
well i got it installed and it froze up when i take it off its not froze up cant find the problem? any help please
Can you be more specific? Can you take some pictures of your set-up here, the whole mess is confusing (to me anyway) and you're getting more confusing answers here than anything. Pictures please...
wow this was a waste of time 80 later and nothing to show for it the dam thing striped out god
I don't see what the problem is, these hubs are as simple as can be. Of course I chunked the band brake, its a piece of crap. But if you replace the cheap chinese bearings with ceramic ones, and then order a custom sprocket from Blow By U(optional, the sprockets that come with it are decent), then these hubs are good to go for 200+ miles a day. For $50 that's not bad. I still wish Grubee would consider reversing the outrer left hand threads, that way a disc brake adapter could be used, the band brake just sucks ass. You can use the lock ring on the sprocket and just toss the entire brake out, worked for me. If you look at the cost of buying all the parts separate, you'd never get close to what they are offering in the package. If you aren't mechanically inclined, better to just buy the whole wheel assembled from bicycleengines.com or Spookytooth.
Put your sprocket on the inside of the screw on flange with the bolt heads on the inside.
