The rope broke on my pull starter so I took it off to replace the rope. The starter self imploded! The little nut had come off and everything got chewed up. But before that it did work. I got the starter from BikeBerry. This time in an effort to spread business around I ordered one from Pirate Cycles.
BikeBerry starter is marked: "ZM"
Pirate Cycles is marked: "Young Xing"
The Young Xing doesn't want to work. I put the washer behind the bell and tighten down the nut. It won't budge a bit. Changed it by putting the washer between the nut and the bell. Same results. If I loosen the nut up, a bunch, it will turn the motor over. But it is VERY sloppy.
Will the Young Xing work some how or should I just return it and get another from BikeBerry?
Terry
Terry
