smileymale
I changed my clutch lever today and had to pull my grip off well i broke my throttle pin lock also any one know what i can do to make it stop spinning on the handlebar now the pin is broke????
ok i broke the little pin that keeps the throttle from not turning it happen because when i was pullin the other grip off i had my hand on the throttle grip and used it to pull also that broke the little pin well what i as thinking of doing was to use crazy glue hoping that will work
Use the same drill bit you used to drill the hole in the handlebars and drill into the throttle casing where the pin was. Get a trim nail (probably a #6 or #8) cut out a piece about 1/4" long and glue it into the hole you made in the throttle casing with a little epoxy.
NAPA has an all metal one fer like $10-15, even the twist tube is metal... no kill switch tho *shrug* It's a better 'nuff throttle that it may be worth havin' yer kill switch somewhere else or jus' using the choke to shut down... there's also no pesky pin, it doesn't need one lol
part # 7-03921
Those finned grips were invented by some sadomasochist BTW, best to plan on replacing them w/some comfy ones![]()
