The aircooled pocketbike engine takes a standard 76mm clutch, so will bolt onto all aftermarket drive systems.Here's another one, sounds like it has a home made shift kit. YouTube - 49cc Mountain Bike. Pocket Bike Crazy, Top Speed ,3 Speed 80+km
Can't you just buy a staton chain drive and mount up the pocketbike motor to it?
I've had three 460 engines, in various forms of power. Two of them hooked up to friction drive, which was a waste of time and money. Even with the tuned pipe, these engines are dogs if you can't keep it in its narrow powerband. Hit a steep hill and you're dead.I use a gp 460 4.2 hp stock.
With a tuned pipe around six hp and still uses 91 octane
This engine will last a while your pocketbike engine wont last.
The pocket bike engines have too small ports to reach 15000 plus rpm like a piped gp 460 can.
The bb88xx is a link to Daves Discount motors.
bb88xx
What size chain are you using? 8mm?Yes I have used the standard 49cc pocket bike engine.. have mounted it on a modified dual suspension mountain bike/bmx. as ur post mentions it has 6 teeth at the front and a 72 tooth sprocket on the the rear wheel which i have attached to a BMX twenty inch hub (diamond back aluminimum) i actually removed three spokes from the hub to attach the sprocket. made mywn exhaust pipe using pit bike components ( has increased the compression)- it works great! i also added a
high performance head and cyclinder kit.. it has a top spead of around 55kmph at the moment, i am using the generic carborator that was supplied currently the motor will rev out quite imprressively ( but does sound like its starving and wants more). am looking for a buzz so am thinking add a beter/sligtly large carb.
also i have an aluminmum whipped cream cannister ( 1 lt) that takes nitrious Oxide was thinking of adding this as well!! View attachment 34229 any way i think they are great motors the last a while as long as you dont burn out the bearing seals from to high a compression or using fuel with know oil
any way if the photo doesnt turn out let me know
55kmph? This is either a weird typo, Or around warp factor 2.it has a top spead of around 55kmph at the moment
Highly possible, since 56kph = 35mph.55kmph? This is either a weird typo, Or around warp factor 2.![]()
do you have a camera? pictures please...I've had three 460 engines, in various forms of power. Two of them hooked up to friction drive, which was a waste of time and money. Even with the tuned pipe, these engines are dogs if you can't keep it in its narrow powerband. Hit a steep hill and you're dead.
Now I'm using it with a shift kit and Happy Time expansion pipe. It's the PERFECT match.
It is the ULTIMATE power setup, and gas mileage and noise level isn't that bad!
