Yep, the pipe fits right under the stock kickstand & crank. I cut this pipe real short for a lotta top end power, & I use a small 'Lucky 7' sprocket.A couple of questions: Are you able to use the stock kickstand or does the SBP exhaust running under the pedal crank interfere with it? Second, the springer fork looks great and is worth having for that alone, but how much real difference does it make with the ride? You have a really good sense of design. Beautiful...
SB
They are standard 7/8" grips... Cut the kit grip off the throttle, & heat up the new grip to get it on.Could you tell me about mounting the grips? Were they both 7/8 or is one 1 in. Do the orginal throttle grips come apart? What trpe of handle bars do you use?
Sweet bike Norm. Let me know if u want me to make a bracket for that pipe and weld it. Just come by my work tomorrow and I will take care of it bro...
