It won't.
The smoke will just blow up behind you and then you will still smell of exhaust. Also, the rubber grips on a lot of kits smell badly of unstabilized rubber and rub off on your clothes.
Extending the exhaust also reduces power and increases heat.
Some of the mix oils smell more/worse than others. Amsoil sabre professional and opti 2 are pretty odorless. It is one reason I use one or the other in the chainsaw which is right up close for breathing it in.
SB
Is the Amsoil Sabre 100:1 mix the recommended mix for our bikes?
Pat
Pirate Cycles has oil that makes the exhaust smell like strawberries, at least thats what the ad says
Recommended by whom? ...
SB
Yes, there are many opinions here. I would discard any which are just opinions and stick to the ones which are experiential... ones which are actually based on regular and successful us of a particular oil. What good is an opinion about an oil one has never used? There is no single answer for you at this forum which everyone will agree on. Another poll won't tell you much anything. For example, most of us who use Opti-2 never heard of it until last summer through retmachinest, so even if it was hands above all the rest (not saying it is, now...) how long it has been used successfully is not a true indicator. Compared to say Walmart brand used by somebody else successfully for the past five years and 3,000 miles, Walmart will sound like the superior oil. Not saying that Walmart oil is not good. I have not used it. I can't use all brands and compare them. No one does. Many sincere people have given input on other threads. Once you have read through it all at some point you have to make a decision for yourself and use your best judgment. Some recommendations will be off the wall and I would put Amsoil at 32-1 in that category. Good luck. The perfect oil in an imperfect engine is... well, just pick one that sounds good to you and go with it. You'll be fine.Recommended by our experts on this forum. I did some reading on this subject in prior posts and have found so many conflicting recommendations. i.e. Amsoil Sabre anywhere from 32:1 to 100:1. I also found conflicting recommendations on the opti 2 stuff also. Im not looking to build a rocket ship but would like to get the longest life out of my engines. Maybe I should start a thread and ask how many miles people have gotten on there engines and what type and mix of oil they use.
Pat
I actually saw that and really want to see if it works. Anyone try this strawberry scented oil? lol
BTW- At least your girlfriend/wife ain't *****en that you come home smelling like a strip joint.
