35-40 MPH, Really?
Status
Not open for further replies.
Sparks66
The motor kit seller's ad says these kits will reach 35-40 Mph after the motor is broken in. I've gone through a couple gallons of gas and have taken the bike up to 28 Mph. Is 35-40 mph realistic without modifications or is this just a way to sell more motors. If these motors do reach 35-40 mph, how many miles or tanks of gas do have to go through to get to 35-40 mph?
I weigh 160 lbs. and my motor kit is installed on a Micargi beach cruiser. (I was 177 lbs. but I completed the P90X workout program).
Thanks,
Sparks.brnot
It depends on how you gear your bike. Large rear sprocket = more torque, less speed. Small rear sprocket = faster but less load capacity. Most folks use the intermediate range 44 tooth and can get to the 25 - 30 mph range.
Thanks Finfan. I am getting out my dremel right now and cutting some teeth off of my 44 tooth sprocket to make it a 36. Don't worry, I won't cut teeth that are right next to eachother.
Yeah, Thats The Idea, About Every 3rd Tooth. Just Take Off 5 To Start With. And Then Try It. You Can Always Do More. Use Safty Glasses. Let Us Know How Much Speed You Gain. YOU COULD BUY A ADJUSTABLE SPROCKET FROM CREATIVE ENGINEERING FOR 18 BUCKS. Ron
this bike goes 45 mph no lie
Your fuel can flow to the carb? my bike is just like yours.. i mounted the tank that way but the fuel wouldnt flow.. So i just set it up this way.. And yeah the bike goes fast.. the frame is really light!
I weigh 132lbs and im 6'1
xct2
It helps if your a 6lbs. 9oz fetus and can reach the pedals. (if you can picture that)
Yes Max it was...It was hillarious too!
I could just envision a noob actually doing this...And then when all else failed, calling me to ask about ordering one of my adjustable sprockets. laff
Jim
...the tank? The fuel tank is prolly just fine like that, it's the float in the carb causing the starvation issue due to the carbs angle...
Through trial and error I've found that while you can mount the carb at a moderate angle - one as extreme as yer just isn't gonna work. Looks as if you've got one of Jim's awesome intakes and it'd be a shame to get rid of that - it there any chance of leveling the engine a bit?
It doesn't need to be perfectly level, but this is about as much carb tilt as ya can get away with - with the tabs bent so far up the lil plug almost doesn't seal;
Sparks- cutting off teeth won't make it go quicker. you need a smaller diameter rear crank to go faster. about a mile an hour gain on the top end per every tooth lower than 44. you loose acceleration and torque but have higher top end.
Jim
What? A joke? Ahhh, thanks a lot guys, I've just cut up a perfectly good sprocket...:(
Status
