Rockenstein
Has the clutch actually worn a lip into the clutch bell? If so the clutch bell is not hardened either in which case if your school has a machine shop I'd take it in and give it a skim.
But it did make a lip right? That's the important info as it will tell you if the bell is hard or soft.
well the gears in my HT only lasted 3000kms and i needed to replace them, so i think that if i get 3000kms to a clutch bell gear then thats just fine, and i will get new ones
I would also consider couple thousand miles good for these Hoot gears. Certainly better than 30 miles.
I' haven't had a HT gear fail yet but then I grease them at least once a year (I also get a haircut once a year whether I need it or not.). One has over 14k miles. I did replace a couple of the small chain sprockets.
Did you grease your HT gears?
Hey Linnix if you need to weld anything, I have a welder at my shop, just let me know.
Thanks
Dude, can I take you to Vegas and split the winnings with you? You have to be one of the luckiest peeps I know of. You can surely weld it back together. If you aren't proficient at it, you should let an experienced welder do it. The way you weld is important.
i think it broke because i welded it to hot and it messed the frames structural integrity up
You welded the bike frame? Why? Any pics?
