You are telling the truth!You guys are getting 40mph? And then some? I'd love to know what I'm doing wrong!
so all the wiring needed is to wrap the wire around the spark plug wire and thats it? does it need to be connected to anything else? what about power supply for the meter, i assume its got its own little battery?rickie h asked "so how are you guys readng your rpms?"
Here is what I did: I learned about inductive pickup digital tachometers. Huh? Go to SenDEC Products Group - Home and look for "inductive meters (surface mount)". A product called TinyTachs uses the same hardware. A wire wraps around the spark plug wire 4 or 5 times. The meter senses the number of spark plug pulses per second and displays. There is one pulse per crankshaft revolution. If you get a tachometer: wrap the pickup wire around the sparkplug wire and then route the sense wire perpendicular to the spark plug wire, else the display will show twice the true rpm count. Cost was less than $45 delivered to your door. Instructions are fairly simple to follow.
MikeJ
I read somewhere the HT engine was designed to putt around town and go 15 mph and use very little fuel . Not to do 30-35 mph like we seem to need to go. So by design if you ride at those speeds and the thing grenades you really have no one to blame but yourself. And all that having been said my bike will do 30 -- 34
who else would you blame?
thats interesting how they have the battery sealed in. i feel kind of weird asking this, is it on all the time or is there a way to turn it off? i figure if they're so serious about the seal that you cant replace the battery, a button would be out of the question.
I'd blame u, for insinuating that these motors "like" to run at such a low rpm...who else would you blame?
Hahaha, that's funny!Or the guy who claims these motors were "designed" at all
A thatsdax 65cc is an engine he sold for a little while with a roller or "needle" bearing in the small end.what's a Dax 65cc? exactly..
Nothing like cruising with traffic at just under 50mph on a motorized bicycle and not have the motor wound tight.
Ok i will have a bite, what motored pushbike do you have that does 60mph? 49cc! 4 stroke?80 cc motors are restricted to a certain number rpm. rpm = speed I run 49cc 10,000 rpm motors with a nine speed amd the jack shaft built into the frame and it WILL hit 60mph I have built many 80-60-45-cc motors they are not built to go here. the CHEAP 66cc design was built with liability in mind if you truly get past 45mph with them you sre lucky by the way 50 to 0ne will destroy your motor does not matter if syn or not speed claims are like ******** every body has one . a opened up ported polished filed carb reworked exaust tuned and weight taken out of the crank and small sprocket on racing fuel gets you 45-48 do not listen to and higher claims with this engine it just isnt true. you will not go much faster with the nine speed kit wiyhout changing the size of the chainring shaka
