cannonball2
I can do the pressure adjust on my direct drives with the clutch cable on the fly. My Mongoose is a spring down engine, while the Schwinn is not. I feel a spring is needed as I have grabbed a lot of throttle on a hill and had the engine oscilate as it over ran the tire. Intend to add one. The lift clutch is perfect for pressure adjustment as you just tighten or loosen at the clutch adjuster on the handlebar. The weight of the engine alone is generally not enough even at around 20lbs for the torque they produce. A spring allows more pressure. When I am in an area of extended flat riding I will reduce the pressure assuming less tire wear. Who knows, but its pretty cool to mess with.
