Hub motor Qs205 50h v3
Controller Asi bac8000
Battery 74v 60ah- 4.4kwh
Max power around 24kw
Max phase amps 510
Max speed: yep
Max acceleration: beats Harleys, loses to Tesla Model S
Forks: Suzuki k10, modded. Stronger springs and fabbed spring perches.
frame: 50% 1980 schwinn cruiser; 50% 2019 American mild steel.
Front hub: 1969 Yamaha 110mm
Rims: 17x1.4 36h aluminum
Tires: front Michelin pilot street blackwall 80/90, rear IRC 90/90
Previous build: 212cc ‘69 Yamaha
Next build: Tube frame ebike build
Original post:
Here’s a build I’ve been working on for a little over a year, riding several months. Haven’t had much time and quite frankly losing interest to finish it, so I thought I might make a thread before I do.
So I’ve been wanting to do a full suspension Chicago cruiser for a while. I almost did so with my 212 schwinn but my buddy talked me out of it at the time, and I ended up doing an 8” chainstay stretch on that one which worked out great.
Here’s the current state of the bike. Not much left of the cruiser frame. This is actually the same frame that I used in my 212er before it got a catastrophic frame crack after thousands of miles which led to me building the 212 Yamaha bike. Needing a rough frame to cut up I did not hesitate to modify the crap out of it.
Not to mention, I lost a 3/8” extension in the seat tube a few years ago, so had a reason to start cutting.
I’ll go piece by piece of course.
The specs are as follows:
80s Schwinn cruiser
19x1.6” rims, 3.25/100-19 tires
Qs205 50h hub motor
ASI 4000 controller
77.7v 24ah 600 amp discharge battery
Suzuki k10 fork, DNM DV22 rear shock
Here’s how it started:
It came out to just over 81.5” long, so just an inch out of the bike size limit for local trains and a quarter inch shorter than my solid drawing.
