silverbear
The Boy Who Never Grew Up
I'm in the early stages of planning out next winter's project, a belt drive 1951 Schwinn Hornet. I'd like to do a build along the lines of msrfan's cool Briggs builds and while still considering the 5 horse Briggs I'm also considering the 6.5 Predator. Either engine has plenty of power. I know the Briggs will fit, but don't know about the Predator. Has any one done it in the Schwinn frame?
An advantage of the Briggs engine is that there are a lot of them around used, parts are readily available and it is a reliable engine made in America. On the other hand the Predator is cheap when on sale (hundred bucks) and mated to a cvt transmission would be a pretty easy build.
Assuming it fits, Do I really need to change out engine parts if I remove the governor? I have no intention of racing this bike, revving it up to the breaking point, pushing it past 35 or maybe 40 mph. As usual, I don't have a lot of money to spend. The advantage of the inexpensive Predator disappears if you end up adding hundreds of dollars of upgrade parts. I can't do it. No, I won't be winding it out, so do I really need to invest in the upgrades?
I do want an engine with some torque... raw power is nice when you want to scoot across the intersection, start out up a hill at a dead stop, add a sidecar with a passenger maybe.
So, will the Predator fit and do I have to do the internal upgrades? Or would I be better off with the Briggs? Thanks in advance for your thoughts on this.
SB
SB
