deacon
minor bike philosopher
Well I think I have most of the safety issues with the new bike worked out now. Some of the issues were solved with simple mechanical fixes others were procedural changes.
My wife convinced me to switch everything to a larger frame. She said I looked like the bear at the circus on a bike. My test bike is a twenty inch BMX type. No brake lever or gears to shift. Plus my feet will sit flat on the ground should I need to do that. But without the battery trailer it is unstable.
So I made the switch to a 26" junked up mountain bike. It is much more stable.
The cable and lever lift makes it easy to get the motor started then to lower it when I'm moving a little. The procedural change was to just let the motor choke to a stop. I have no idea how bad this is for the motor but I'm sure it's better for me than trying to juggle everything and still get the bike stopped. Once the bike is stopped I lock the motor up while I maneuver the bike around. I can either drag start it or reach around and pull the cord.
I bought a new drive wheel yesterday from the bike shop. I bought a 3/4" diameter axle peg that was drilled all the way through. It is almost perfect for the 5/16 bolt to go through cleanly. There is very very little play around it. The texture is very very deep cuts. It will probably shred the tires. I am considering filling it in with JB weld if it does eat things up.
