Where do I find the tall head nuts?
Discussion in 'Motorized Bicycle General Discussion' started by Rudz, Jan 5, 2015.
  1. Rudz
    Rudz New Member
    Jun 24, 2014
    454
    I don't know what they're specifically called, I just know they're m8 1.25 nuts
  2. 2door
    2door Moderator
    Staff Member
    16,301
    26
    I'm assuming you're talking about cylinder head fasteners on a Chinese 2 stroke?
    Standard hex nuts will work but I prefer what is called, 'flanged or shouldered' nuts. They have them in smooth or with locking teeth. I buy mine at Ace Hardware. Look in their metric fastener section.
    Just make sure to use a torque wrench when installing the head. 120 to 140 inch pounds.
    #2 2door, Jan 5, 2015
  3. Davezilla
    Davezilla New Member
    Mar 15, 2014
    2,708
    What 2 Door said... but if you can't find then locally, crmachine.com , Fred will most likely sell you a set of the ones he makes if you call him.
  4. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,514
    48
    I see them on some motors coming in for repair - about twice the height of usual - don't know what kits they're on tho. I doubt they'd ever give the binding problem.
  5. Flyman
    Flyman New Member
    Nov 28, 2014
    258
    Those are acorn nuts.If they are bottoming out before they seat, just
    cut the top off.Problem fixed.
    Fly
  6. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
    Here ya go
    $10 shipped to your door for a full set.
    If your have a GT5 engine like a Grube like Gasbike.net sells, Kingmotorbikes or Piston bikes these may not be the correct thread, but if you have a PK-80 type engine these should fix you right up.
    I'm assuming you are looking for this tall of a nut like is used on some of the aftermarket heads.
    Yes Fred is a choice and also this seller has them.
    http://www.ebay.com/itm/MOTORIZED-B...994?pt=LH_DefaultDomain_0&hash=item418bd7195a
    #6 mapbike, Jan 8, 2015
  7. maniac57
    Oct 8, 2011
    4,486
    My local Ace sells them. "Coupler nuts" in various sizes. Some stores even have them with the nice dome heads like the ones that come with a Fredhead.
  8. crassius
    Sep 30, 2012
    3,514
    48
    those ebay ones aren't what I'm seeing on some bikes - I sometimes see them with threaded portions that long, but also have nice acorn tops
  9. Rudz
    Rudz New Member
    Jun 24, 2014
    454
    I like the mzmiami ones, thanks guys
  10. mapbike
    Mar 14, 2010
    5,380
    You're welcome...
