What's your average speed?
What's your average speed/ total weight on the tyres?
  • Total voters
    37
Bike: Small Mountain
Engine Size: 66cc
Drive type:chain drive, 44 tooth rear sprocket
Load weight:22.6796kgs+- (50+-lbs) for bike, 75kgs (165.347lbs) for rider
Terrain: flat and with hill at 2.5Deg. sandy compact roadside
Area: semi suburbia
Average speed:40kmh (24.8548 mph)
Top speed: 58+km/h (36.0395+ mph) flat, 63km/h (39.1464mph) downhill at 2.5Degrees.
Mods:
polished head dome
ported exhaust, matched intake/cylinder ports. trimmed gaskets to match holes where cylinder meets bottom end (forgot the term for that spot)
NT carb (not a mod)
Notched cylinder skirt (awesome mod btw)
teflon top- end bearing retainers made from teflon sink washers drilled out and sanded down.
KMH 415 BMX chain
Echo power blend oil
Your idling speed is my average:) I understood that an engine should not be idled high enough to propell the bike?
I've not heard that before... might be something to it, might not. I mentioned it because when Harley and I are out for a ride, I usually idle along with her while she has some throttle open (not a lot, she's not a speed freak like I am ;) ). I'm not sure what the top speed on her bike is, it's only just past break-in and she's not one to wind it out the way I do. I think her TS is around 40-45 kph, using the same 66cc but with a 48T sprocket on the wheel (and a bit more over-all load on the motor). If I ride her bike (apart from my knees hitting my elbows when I pedal) it'll pop the front end up if I drop the clutch at high RPMs due to that torque sprocket.
I've always run high idle speeds, years ago when I was a delivery guy my beaters used to be dialed in to idle at around 45 kph, just a little below traffic speed.
(By the way folks, a quick guideline is that 10 kph / km is a little over 6 mph / miles [6.21 if you want to get finicky about it].)
Bike: GT LTS Mountain Bike
Engine Size: 69cc Dax F80 W/Rt Carb & SBP Pipe
Drive type:SBP Shift Kit W/9T Output Sprocket, 8 Speed Derailleur
Load weight: Bike-60 lbs Rider 215 lbs
Terrain: Dirt roads, Trails, Hill climbs, Street
Average speed: About 15mph (lots of slow technical trail & hill climb)
Top speed: 35.8 mph on Street- 32.4 mph on dirt
My bike is a tank (60 lbs) for being an aluminum frame, the shift kit is a good part of the weight, Im gonna change that with aluminum sprockets.
Bike: trek motorized bicycle, 26"wheels, 21" frame
Engine Size: 66ht
Drive type:41 roller chain on 50t sprocket
Load weight: Bike-85lbs Rider 180lbs
Terrain: anywhere
Average speed: 29 KPH
Top speed: 52.3 KPH
Bike: Felt Slant
Engine size: Hua Sheng 49cc
Drive type: 4G transmission, chain
Load weight: approx 190lb (I have never weighed it :))
Terrain: Hilly asphalt, hard packed dirt trails, grass, loose dirt
Area: Town, neighborhood, trails
Average speed: 21mph
Max speed: 38mph
Happy Riding!
-Chris
motor 80cc ? china girl
standard kit chain drive
me 185 lbs
country black top simi smooth
5 min = 2.1 miles 2.1 x 12 = 25.2 MPH
still lots of throttle left I ran it full speed and it burnt out the CDI have replaced CdI and will stay at a comfortable ride at the above average
Update: Now running 36 tooth and loving it! Perfect powerband with my pipe setup and much calmer cruising. Very nice for flat areas even with a big guy like me!
Bike-Diamondback Response w/203mm disc brakes, 26.5" Scwalbe Big Apples
Motor-Tanaka 47R 2.8hp w/ 3-piece Tanaka pipe
Drive-8/speed shift kit-46.3:1 First gear, 15:1 Eighth gear
Bike weight-60lbs; Rider-200lbs; Load-20lbs.
Road terrain-flat asphalt w/ two steep hills
Time traveling 6 miles roads, bike path and heavy traffic-20 minutes
Average speed, including waiting for all traffic stops-18mph
Cruising speed-30mph
Top speed- Untestedxct2
Most of my details are in my sig
Bike: Gary Fisher Capitola (cruiser/commuter)
Engine size: 66cc HT
Drive type: 415 Workmans chain on a 36t
Load weight: 195 + bike weight
Terrain: Las Vegas urban
Average speed: 26-29mph
Max speed: depends on the conditions 33-37mph
Fuel mix: 50:1 Homelite
Speed carb
Magacor spark plug wire
NKG B8HS
SBP expansion pipe
Approx engine mileage:420
Bike: Cruiser
Engine size: 50cc China Girl
Drive type: Chain, 44T sprocket
Load weight: Around 155 lbs / 70kg
Terrain: Flat, all asphalt/concrete
Area: surburban
Average speed: 25 mph (flat)
Max speed: 32 mph
Bike: Cruiser
Engine: 66cc China Girl (no mods, everything stock)
Drive type: Chain, 40T sprocket
Load Weight: Me-155lbs, bike don't know, going to guess 50lbs
Terrain: rolling hills
Area: city/rural
Average Speed: 22-24MPH
Max Speed: 32MPH on a flat
Bike: Cranbrook Cruiser
Load Weight: Me-120lbs, bike don't know, going to guess 50lbs
Terrain: flat/hills
Area: city/rural
Average Speed: 17.5MPH
Max Speed: 32MPH flat
Bike: 29" motorized bicycle
Engine size: 66cc X80
Drive type: direct 56-tooth sprocket
Load weight: 350lb
Terrain: slight hills / asphalt
Area: Everywhere
Average speed: ~22mph
Max speed @ ~7500 RPM:
picture.php
On my Huffy Karaoke I cruise @ 32-34mph
On my Kulana with the Dax Gen IV I cruise at 40-42mph
On my older first build mountain bike I cruise at 28-30mph
Map
.wee.
Excalibur ‘09
Bike- Made from various antique bicycle/motorcycle parts.
Engine- 1939 Wisconsin model AK (17.8 cubic inches)
Drive- Belts/jack shaft- Slipper clutch
Weight- 220 lbs. Bike only
Terrain- City streets with many steep hills.
Typical cruising speed- 15 to 20 mph
Max speed- 30 mph
Robert Thumper
Bike- 1960 Schwinn cantilever, rear triangle stretched 5”
Engine- Greyhound 200 (200 cc)
Drive- CVT with chain secondary 9t to 48t final.
Weight- Apox 100 lbs Bike only
Terrain- City streets/country roads with many steep hills.
Typical cruising speed- 35 to 40 mph
Max speed- Low 50’s mph
On a calm day the Auffenauger will cruise at 30 and top out at 35 with a Honda 49cc 4-stroke engine and a 40-tooth rear sprocket. With that gearing it doesn't handle hard headwinds well.
Peerless Leader also has a 49cc Honda 4-stroke and is geared lower with a 48-tooth rear sprocket and will cruise at 20-25 easily in almost any type of wind.
Mr.B, those bikes are really something. I can't tell you how much I like that '09 Ecaliber.
Btw, the average top speed of the earliest HDs, Excelsiors, etc, etc, were pretty much all within the 30-40mph range. You gotta like the fact that many of the reported top speeds on this thread reflect very favorably with that of these early motorcycles.
I don't know mine goes faster than I can peddle for any length of time . I haven't found a speedometer that works on my motorized bicycle yet . I have mostly decided it gets me from point A to point B and back so I am happy .
Excalibur ‘09
Max speed- 30 mph
Robert Thumper
This is a pair of beautiful bikes.
Finished! (for now)
Please go to: MB.COM average speed poll results.
Thanks for all the input!(^)
