What's your average speed?
What's your average speed/ total weight on the tyres?
  • Total voters
    37
Trey
$50 Cruiser
I intended to go very slowly, but I find myself going faster than I would have thought. I'm curious about the rest of you.
To make it quick, how about this format? Suggestions are welcome.
Assuming acceptable weather and road conditions;
Bike: cruiser
Engine size: 49cc
Drive type: factory gearbox, chain
Load weight: 200lb (you, your gear etc)
Terrain: mostly flat, asphalt
Area: in town
Average speed: 15mph
Max speed: 26mph
Bike: cruiser
Engine Size: 66cc
Drive type: factory chain drive
Load weight: 65lbs for bike, 185 for rider
Terrain: flat with hills exceding 20*
Area: in town
Average speed: 23 mph with stops included
Top speed: 32 flat, 39 downhill.
Bike: Mountain
Engine size: 66cc
Drive: #40 hd roller chain
Load (me)275lbs
terrain: mostly flat
Area: city
Average speed 20mph
Max 31.1
Bike: cruiser
Engine Size: 66cc
Drive type: chain drive
Load weight: about 225
Terrain: asphalt
Area: downtown
Average speed: 25
Top speed: 32
Bike- Cruiser, 27 x 1 1/4 alloy rims
66 engine- NT speed carb on billet intake
415 Trike chain, 34 alloy cog
bike weight- 40-45 (someday I'm gonna get a scale)
My weight- NTB- not terribly bubba
Terrain- flat smooth Florida suburban- too much glass!
Average speed 28-30 on analog speedo
Top speed 35 plus
Bike Cruiser, 700 C x 32mm tires, alloy rims
50 cc, NT speed carb on billet intake
415 trike chain on alloy 39-
bike weight 40 lbs estimate
average speed 22-25
top speed 28
I've ridden the 50cc now much much more- it just runs and runs- and several pounds lighter
Wow. I'm surprised how close all those speeds are to each other. I like the addition of the 'max speed' line!
Bike: Mountain Bike
Engine size: 60cc
Drive type: factory drivetrain (chain)
Load weight: 70kg
Terrain: slight hills, asphalt
Area: surburban
Average speed: 20kph (I ride with non-motorised bikes often)
Max speed: 43.3kph
I'm looking to optimize the gearing to run in the engines sweet spot at my normal cruising speed. (about 20-23mph) Looks like this will turn the trick!
Bike: Mountain/cruiser
Engine Size: 160cc
Drive type:Single speed belt
Load weight: 140
Terrain: Flat with some overpasses.
Area: In town and country
Average speed: 30
Max speed: 50
Engine Size: 68cc
Drive type: chain 36T
Load weight: 190
Terrain: Many small hills long stretches of country side
Area: College campus and surrounding neighborhoods
Average speed: 20
Max speed: 36
99cc Predator
EZM Q-Matic
Changed front pully to 2.5"
56t rear
26" wheels
Gov removed
1" header
re jet carb
WOT 47mph
cruse 30-35 all day
Bike:cruiser
Engine:grubee 66cc
Drive: standard chain, 36t rear sprocket
Load weight: 160lbs rider, about 35-40 bike
Terrain: paved roads, always sloped, lots of hills
Area: city streets, lots of stop lights/stops,
Average speed: 39mph (just to clarify why its so high...i just go wot all the time. I ride a ticking time bomb basically)
Max speed: 46mph
Bike: Mountain Bike
Engine size: 66cc China Girl
Drive type: Chain, 36T sprocket
Load weight: Around 155 lbs / 70kg
Terrain: hilly, flat, bridges, all asphalt/concrete
Area: surburban
Average speed: 45 kph / 28 mph (flat) and 29 kph / 18 mph uphill.
Max speed: 58 kph / 36 mph
My 'idling speed' (where it will put along with no throttle at all on flat ground) is around 30-33 kph/18-20 mph.
I have had it to 68.9 kph / 42.etc mph coming down the bridge, but that's where the bike itself began a speed-wobble beneath me, so I had to cut the throttle and let it settle down a bit.
Your idling speed is my average:) I understood that an engine should not be idled high enough to propell the bike?
Bike: 26" motorized bicycle
Engine size: 49cc
Load weight: 220lb
Area: country
Average speed: 20mph
Max speed: 29mph
Great! So far our weight on the tyres is: 275lbs, and we ride at: 25mph. Knowledge is power, and there's alot more here.
Let's get as many members as possible to give their feedback here. Then we can talk about braking and other issues with some mathematical info.
Thanks for the help!.we..wee.brnot
Depends on the bike
120cc 4 stroke, 30/44 - street
66cc 2 stroke with jack shaft 24/30 - off road
66cc 2 stroke single speed 20/26 - street
Lots of hills where I live
