mojoman288
Power Drill......Check
Blue Loctite......Check....
anything else?
For engine mounting and for bike:
NOTE: you can susbstitute a couple of adjustable wrenches in place of the others
10mm wrench and 10mm socket or 2 10mm wrenches = all nuts + brakes
14mm wrench and 14mm socket or 2 14mm wrenches = tensioner bolts + nuts and bike seat
15mm wrench = bike wheel nuts and for removing peddals
flathead screw driver = all cover screws and muffler cap
philips screw driver = carb clamp + carb drain
Sharp heavy duty wire cable cutters = clutch cable
large adjustable wrench = only if removing peddal cranks
Set of allen wrenches = handle bars + brake pads
Black electrical tape
Plastic ties
good Chain breaker/hack or power saw + pliers/punch + hammer/ your choice = chain
drill and drill bits = optional
Teflon tape = gastank petcock threads
high temp tube of Silicone "auto car type" = around intake to carb connection + use on gaskets
extra fuel line = i use clear line : 3/16" I.D. x 5/16" O.D.
extra 10mm nuts
roll of paper gasket for making new gaskets "sold in auto supply or hardware stores"
Plastic ties
extra 10mm nuts
