What tools will I need
Discussion in 'Motorized Bicycle General Discussion' started by mojoman288, Jun 1, 2010.
  1. mojoman288
    mojoman288 New Member
    Apr 26, 2010
    26
    zptWell, I might be buying a 50cc 2 stroke kit real soon, I really want to know all the tools I need, I already have the perfect bike ready, but what are all the tools I need?
    Power Drill......Check
    Blue Loctite......Check....
    anything else?
  2. Bikeguy Joe
    Jan 8, 2008
    11,529
    A drill??? I have never used a drill except for the chain tensioner mod I did once.....but could have lived with out it, like the other bunch I built.
    A 10mm wrench or two, some locking pliers, a plug wrench (usually comes with the kit) and a set of screw drivers.
    A chain breaker is a nice addition, but you have to get a decent one, not the wart mart kind.
  3. GoFastBicycles
    GoFastBicycles New Member
    Jul 29, 2008
    560
    Timing light wheel balancer lift and a muffler bearing tool.
    Kidding couldn't resist.
    Most important tool is Joe's brain......
    Adam
  4. Cabinfever1977
    Cabinfever1977 New Member
    Mar 23, 2009
    2,290
    For engine mounting and for bike:
    NOTE: you can susbstitute a couple of adjustable wrenches in place of the others
    10mm wrench and 10mm socket or 2 10mm wrenches = all nuts + brakes
    14mm wrench and 14mm socket or 2 14mm wrenches = tensioner bolts + nuts and bike seat
    15mm wrench = bike wheel nuts and for removing peddals
    flathead screw driver = all cover screws and muffler cap
    philips screw driver = carb clamp + carb drain
    Sharp heavy duty wire cable cutters = clutch cable
    large adjustable wrench = only if removing peddal cranks
    Set of allen wrenches = handle bars + brake pads
    Black electrical tape
    Plastic ties
    good Chain breaker/hack or power saw + pliers/punch + hammer/ your choice = chain
    drill and drill bits = optional
    Teflon tape = gastank petcock threads
    high temp tube of Silicone "auto car type" = around intake to carb connection + use on gaskets
    extra fuel line = i use clear line : 3/16" I.D. x 5/16" O.D.
    extra 10mm nuts
    roll of paper gasket for making new gaskets "sold in auto supply or hardware stores"
    #4 Cabinfever1977, Jun 1, 2010
  5. Kevlarr
    Kevlarr New Member
    Jul 22, 2009
    1,628
    If you have one I've found that putting on the sprocket and rag joint with a cordless impact driver works great.
  6. Goat Herder
    Goat Herder Gutter Rider
    Apr 28, 2008
    6,251
    Left out the really big hammer! I like to threaten my projects with harsh words too..laff
  7. Cobra GT
    Cobra GT New Member
    Apr 16, 2010
    23
    and a snorfblat pullin hama is a nice addition
  8. mojoman288
    Apr 26, 2010
    26
    Wow thats alot of stuff, How much of that do I ABSOLUTLY need, and what can I bypass?
  9. Goat Herder
    Apr 28, 2008
    6,251
    The kit will come with fuel line and should have a filter as well
    I would assume that you have been up keeping your own bike or bikes?
    One should have maintaining a bike under there belt!
    With that said this is a fun hobby but comes with a reasonable need for understanding maintenance. That list is a pretty decent list feel free to ask more questions. This is a great forum and folks will help! There are no dumb questions here !
    This is a good read might fill some blanks on things not asked yet!
    http://motorbicycling.com/f30/guide-bicycle-motor-preparation-care-354.html
    If you skim through here there is a ton of info!
    Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits - Bicycle Engine Kit Classic Posts at Motorized Bicycle Forum
  10. Cabinfever1977
    Mar 23, 2009
    2,290
    Mojoman288 here is a cheap basic tool list:
    Medium size Adjustable cresent wrench
    2 10mm wrenches (you can use a couple of adjustable wrenches but it wont be fun)
    wire cable cutters
    Plastic zip ties
    good Chain breaker for 415 chain (or punch and hammer)
    high temp tube of Silicone "from autopart store or section"
    Really big hammer = optional
    #10 Cabinfever1977, Jun 2, 2010
