4you2eat
Here ya go !
One Wallyworld Fat Tire Mongoose w/ a 79cc Predator coming up.
Im not too sure about the tires, they look cheap, too cheap to be safe. I will probably get some Origin8 Devist8er tires to replace them
I ordered a 11 tooth 5/8" Max Torque Clutch & 4' #35 chain, 30 tooth #35 jackshaft input sprocket, 10 tooth #41 jackshaft output sprocket, adjustable bearing hangars, 12" 5/8" jacksahft, 5/8" jackshaft collars from OMB and a hub adaptor w/ 48 tooth sprocket from Manic Mechanic. I see I will probably have to modify the left seat stay to allow room for drive chain and modify the brake arm to allow drive sprocket to come out enough to give chain clearance to avoid tire rub issues. Im removing the governor and will prolly build a custom air filter box. Gas tank will be made from 22ga sheet steel.
I'm going to fabricate a custom exhaust using 3/4" EMT and probaly use a kit muffler since the bike is being built for a customer who wanted the bike reasonably quiet
Im videoing the build and will get the highlights on YTube here soon. more 2 come !
Here's the motor.
Yellow is where Im gonna cut the frame
here is the frame so far w/ 1 1/2" x 16" angle iron brazed in for motor mount
I will add 3/4" round tubing as indicated in yellow below. I shall fabricate a gas tank to fit in the yellow area.
Removed the governor as shown below
Here's the motor.
