Use current bicycle gears??
Discussion in 'Motorized Bicycle General Discussion' started by cschade, Aug 8, 2014.
  1. cschade
    cschade Member
    Aug 8, 2014
    51
    Hello, I'm thinking about building a motorized bike using a Harbor Freight 3hp engine. Two questions -- first, on the Harbor Freight website it says the shaft rotates counter clockwise. Is this counter clockwise as viewed from the visible end of the shaft? Also, I'm thinking about using the pedals of the bike as a jackshaft. For instance, mount the engine so the engine shaft is sticking out the left side of the bike as viewed from the seat. Then, run a chain from the clutch to a sprocket mounted on the left side of the pedal crankshaft, opposite of where the sprocket is normally mounted. Then, let the engine turn the bikes gears. I've attached a sketch. Can this be done. I'd have to cut off the pedals and mount foot pegs somewhere else. Thoughts?
    .scratg.
  2. The_Aleman
    The_Aleman New Member
    Jul 31, 2008
    2,658
    Counter-clockwise is while facing the end of the shaft, yes.
  3. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,566
    58
    knew a guy just turned his pedal crank around to sit on left & reversed rear wheel and freewheel action
  4. 2door
    2door Moderator
    Staff Member
    16,304
    29
    Check your local laws before removing the pedals. Some jurisdictions require them or they will call your bike a motorcycle and will require motorcycle registration, insurance, etc.
    Do some reading here on the Harbor Freight engine conversions. Use the search feature or check the DIY section for non-kit engine installations. I feel you have a lot to learn before attempting this installation. Good luck.
  5. cschade
    cschade Member
    Aug 8, 2014
    51
    Please, more info!
  6. cschade
    cschade Member
    Aug 8, 2014
    51
    Thank you, and you are right -- I have a lot to learn! The only motorized bike I've built before was friction drive, so I'm not used to chains and sprockets :).bf.
  7. cschade
    cschade Member
    Aug 8, 2014
    51
    Another question -- how many teeth should the sprocket be (with the chain running from the engine to the jackshaft). There are some pretty big hills around where I live, but I'm only 130 lbs. 30 tooth, 40 tooth, 60 tooth?
  8. crassius
    Sep 30, 2012
    3,566
    58
    he just turned stuff around, I believe the only thing he bought was the freewheel that ran in the other direction
  9. cschade
    cschade Member
    Aug 8, 2014
    51
    Thanks! Do you know where he got the freewheel from, or it is possible to change the direction of the freewheeling?
  10. crassius
    Sep 30, 2012
    3,566
    58
    not sure if he turned the pawls around on it or it came that way, but I seem to recall it was threaded backwards too
    this was maybe a year & 1/2 ago
    you should try googling
    he had a progressive drive on a 4-stroke that was a lot easier if it came out on the right side
  11. BarelyAWake
    BarelyAWake New Member
    Jul 21, 2009
    7,209
    I'm not recommending these outlets, dunno beans about 'em other'n they had the handy info to link - as always, shop around ;)
    & if you'd like a reversed freewheel w/that;
    http://www.treefortbikes.com/product/333222380078/945/ACS-SouthPaw-Freewheel-1-and-8.html
  12. cschade
    cschade Member
    Aug 8, 2014
    51
    Thank you for your help, everybody. I've been doing a lot of reading up on the subject, as someone suggested. Another question I have is: how would I go about mounting the larger sprocket on the cranks? And, what size sprocket would you recommend? I'm leaning toward a 50 tooth with a 12 tooth on the clutch, because I have a lot of hills where I live. What are your thoughts?
