Upgraded chain
Discussion in 'Motorized Bicycle General Discussion' started by Flounder, Jun 29, 2010.
  1. Flounder
    Flounder New Member
    May 26, 2010
    65
    Hey people.. I just want to throw this out their. The chains that come with these kits are nothing but junk..They stretch and stretch and constantly pop off....Throw them AWAY!.. I just put on a #41 chain
    yesterday and have had zero problems... My bike was setup perfect. All my problems were the results of an inferior product.. You can save yourself's a a lot time and grief by running down to Northren tool and picking up a Drive Chain #41 | Chains + Sprockets | Northern Tool + Equipment and dont forget a
    Heavy Duty Chain Breaker..
    usflg
  2. FlyingHorse87
    FlyingHorse87 New Member
    Jun 27, 2010
    24
    The chain that comes with these kits isn't the best, mine stretched significantly over 3 days of running, that could also be attributed to me riding up very steep hils and weighing 250. I replaced mine with KMC 415H free style chain, it was arond $13.00 and is much higher quality than the original. Another easy way the seperate chain without a chain breaker is to carefully grind down the pins on a bench grinder WEARING GLOVES, then put a chisle or large straight blade beater screwdriver between the side plates and tap it with a hammer. They will come right apart with no damage.
    Evan
  3. nidyanazo
    nidyanazo New Member
    May 25, 2010
    316
    I use this one:
    [​IMG]
    Pricey, but it'll last the lifetime of the bike/motor
  4. Chrismbello
    Chrismbello New Member
    Nov 8, 2009
    39
    Just wondering, will that chain breaker work with the 415 chains?
    Thanks,
    Chris
  5. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    nidyanzo,..what chain is it ,I cant read it on the box,thanks
  6. Goat Herder
    Goat Herder Gutter Rider
    Apr 28, 2008
    6,251
    I am not totally familiar with this chain stretching out deal. All my bikes that were stock I did run teisoners on them usually upgraded to a custom shaped skate board wheel was the only set up I ever truly liked . Much smoother than the stock wheel in the kits huge difference. All my friends around me so far including me never had a problem with the stock chains. My first kit I put about 6000 miles on the kit chain and motor. The out put cog on the engine had a lot of wear though. It never missed a beat.
  7. xzackx
    xzackx New Member
    Jun 30, 2010
    44
    i just got done ordering #41 chain too because my original chain was not long enough for my schwinn stingray, so far its been running pretty good
  8. Mind_Reader7
    Mind_Reader7 New Member
    May 1, 2010
    393
    I use the stock chain. I never had a problem, besides with stretching, which is what the tensioner is for.
  9. Flounder
    Flounder New Member
    May 26, 2010
    65
    It is suppose to, but Ive never tried it.
  10. Flounder
    Flounder New Member
    May 26, 2010
    65
    The tinsil strength on these chains are 2800lb compared to kit chains which are 1200lb tinsil.
    Less stretchy more ridy =)
    I know kits vary ...My troubles come from the gt5 kit..Being the only kit I ever owned.
    #10 Flounder, Jul 2, 2010
  11. xzackx
    xzackx New Member
    Jun 30, 2010
    44
    i bought a #41 roller chain in a 10ft section and i had to use 5 feet of it for my chopper i used a dremel tool to grind off each side of the middle pin and used a punch to knock it out takes longer but works
