Universal Tachometer
Discussion in 'Motorized Bicycle General Discussion' started by Vistaman73, Jan 2, 2010.
  1. Vistaman73
    Vistaman73 Chat Box Junkie
    Nov 29, 2009
    247
    Has anyone heard of these? I guess a wire is wrapped around the spark plug cable and when it picks up a current it can show the rpms. I would love to find a nice one. any suggestions?
    laff
  2. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    Like this?
    ENM 2 Cycle Two Stroke Tachometer Tach
    It acts like a timing light, but instead of lighting up every time there's current through the plug wire, it measures how many jolts go through it and displays as RPM.
  3. Vistaman73
    Nov 29, 2009
    247
    kind of... but it says it refreshes every 2.5 secs. little slow, there are others on the site but they are more money, i guess i will do some research.
  4. Vistaman73
    Nov 29, 2009
    247
  5. azbill
    azbill Active Member
    May 18, 2008
    3,367
  6. Vistaman73
    Nov 29, 2009
    247
    that is a nice tach. it is a little exspensive though. i am also getting a speedo with odometer. so i will have RPM, Speed, Hours, And Miles. But, I guess if i want to be accurate i should not start my new motor until i get those two things. now i am bummed that i have to wait.
    #6 Vistaman73, Jan 2, 2010
  7. robin
    robin Member
    Nov 15, 2008
    615
  8. Vistaman73
    Nov 29, 2009
    247
    does it update every 2.5 sec?
  9. TheE
    TheE New Member
    Jun 26, 2009
    187
    I was in the process of building a homebrew digital tachometer that refreshes every 1 sec (adjustable). I had the program done and everything, but then winter hit :( Gotta wait for the summer to build it and try it out...
    #9 TheE, Jan 3, 2010
  10. Vistaman73
    Nov 29, 2009
    247
    That looks like the same thing made by a different brand. How often does it update? 2.5 Sec? thst seems too slow. if it does, how do like it?
  11. robin
    robin Member
    Nov 15, 2008
    615
    Iam just using mine to tell me hours so i change oil at the right intervals--i think it updates instantly but i will tell you tomorrow
  12. warner
    warner New Member
    Jun 5, 2008
    60
    I'm using the one Staton sells, too (SenDEC). There IS a slight delay....but unless you are used to seeing a bouncing tach needle, it's adequate. It tells you what your cruising RPM is...and you can see how high you're revving and whatnot. And doubles as an hour meter, so that's a nice bonus. Good unit. Simple to install. You won't regret getting one.....very slick little meter.
    Warner
