110 to 120 inch pounds I have a post on top end work, shows the pattern, how I do the torque sequence. Hope this helps you
Norman
General Discussion on Motor Bicycles
Engine top end rebuild and an engine stand
You can approximate 12 ft/lbs. by grabbing a 3/8 drive ratchet at the "head" (do not grab it by the handle, you'll pull the threads out of everything you tighten!) and tighten it as tight as you can get it....if you're a brutish fellow.
