top speed for slightly mod 66cc?
Discussion in 'Motorized Bicycle General Discussion' started by Legwon, Mar 15, 2013.
  1. Legwon
    Legwon New Member
    Mar 2, 2013
    248
    ok so i hit up 50km on flat terrain today on my 66cc monster
    ported, 41 chain, speed carb, and 50tooth spocket
    does that sound right??
    its a 2stroke China engine
    #1 Legwon, Mar 15, 2013
  2. biknut
    biknut Active Member
    Sep 28, 2010
    6,378
    That's good, but anyone should be able to do that with a bone stock motor. BTW you're over reving your motor. That would be high rpm with a 44T unless you have a 29er.
  3. Legwon
    Legwon New Member
    Mar 2, 2013
    248
    doesn't sound like over-revving. i have over-revved it in the past, so i know what that whine sounds like.
    its a steady throttle, sitting about 90% ,,, not WOT
    also, the bike itself weighs about 50-60lbs
    heavy little beast!!
    #3 Legwon, Mar 15, 2013
  4. Venice Motor Bikes
    Mar 20, 2008
    6,192
    19
    A ported HT with a large expansion pipe & jetted carb with a 40T rear sprocket should be able to hit 40 MPH. (give or take a few MPH). ;)
  5. CTripps
    CTripps Active Member
    Aug 22, 2011
    1,311
    Sounds like you're in the right zone to me. On my beast I run a 66cc (the ports have been cleaned up and I lapped the head) with NT speed carb, stock exhaust and a 36T sprocket. I can get close to 60 kph on flat ground. If I stripped the carriers etc to reduce weight and drag I'd probably get a bit over 60 at the top end.
  6. Maxvision
    Maxvision New Member
    Jun 13, 2009
    551
    Over reving? GAWD, I LOVE the sound of the 2 strokes when they SCREAM. I'd scream my stretch cruiser with shift kit every chance I could. Went through a few cylinders from heat build up but at $20 a pop for cylinders...I LOVE the sound of a 2 stroke when it SCREAMS
    [​IMG]
  7. biknut
    Sep 28, 2010
    6,378
    That's about 31 mph? That sounds about right for a 41T.
