tight chain
Discussion in 'Motorized Bicycle General Discussion' started by oldsurfer, Jun 18, 2010.
  1. oldsurfer
    oldsurfer New Member
    May 21, 2010
    126
    how tight should you chain be...to tight i would think would have advers effect on the motor???????????
  2. 2door
    2door Moderator
    Staff Member
    16,310
    1/2 to 3/4" slack is ideal. Any more or less and you could have problems. Measure the slack by leaving the clutch engaged and rolling the bike forward. The upper portion of the chain will go slack. Measure at the center of the chain span between sprockets.
    Hope this answers your question.
  3. oldsurfer
    May 21, 2010
    126
    tom my guy had the chain so tight you could use it as a gutiar..how do you get the chains both at the right tension? any thought would be helpful
  4. GearNut
    GearNut Active Member
    Aug 19, 2009
    5,105
    Check out chain tensioners on this forum. Some folks put a tensioner on the pedal chain and nothing on the engine chain, others use a half link on the engine chain to get the overall length close enough to avoid using a tensioner.
    Here's a link to a informational thread:
    http://motorbicycling.com/f4/chain-tensioner-falling-into-spokes-mystery-19727.html
    In my post, #6, I linked to another thread that shows one of the safest ways (IMHO) to use a tensioner on the engine drive chain.
    #4 GearNut, Jun 19, 2010
  5. oldsurfer
    May 21, 2010
    126
    thanks gearnut..greatadvice
  6. Tinsmith
    Tinsmith Member
    May 15, 2009
    971
    13
    I've been running a spring loaded tensioner for a year now and have not had any problems. I switched to #41 chain and replaced the Tractor Supply spring loaded roller with a sprocket. Works great for me.
  7. jared8783
    jared8783 New Member
    May 13, 2009
    216
    I have been wanting to do this for some time now
    I got a tensoiner on order from tsc but where did you get the sprocket to replace the roller
    i didnt see any that seemed small enough at tsc
  8. Tinsmith
    Tinsmith Member
    May 15, 2009
    971
    13
    I guess I need to elaborate a little more. I don't offer a lot of advice 'cause my knowledge on these bikes is fairly limited. I mostly read. I am an old metal worker in a machine shop so I forget sometimes that some things aren't that simple. I had a 2-3/4 inch 15 tooth #41 sprocket laying around and also a bearing for it. I had to bore out the sprocket and press in the bearing. You might want to try out the roller. From some of the past posts I've read, a lot of the fellas are real happy with the roller. It already has a bearing in it and it's quiet. If I remember correctly, some have gone to the hardware store and bought a small stiff "helper" spring. You should be able to attach it to one of the mounting bolts and you may have to drill a small hole in the arm to attach the other end. I will see if my wife can show me how to post a picture of what I did. It's not fancy, but works well.
  9. Tinsmith
    Tinsmith Member
    May 15, 2009
    971
    13
    Here are a few photos of my modification of the Tractor Supply spring-loaded roller tensioner. I mounted it on the down tube and cut and welded the stock kit roller in a different configuration. I had some #41 chain and a sprocket so I swapped out the roller for the sprocket. Pressed a bearing into the sprocket and added a helper spring. The sprocket has plenty of lateral movement so it runs where it needs to. Haven't had to touch it since I installed it a year and a half ago. Hope this might be helpful. Dan
  10. oldsurfer
    May 21, 2010
    126
    Give Me The Tractor Supply Parts # For The Tensioner And The Spring...and The Sproket So I Can Order It...can't Seem To Find This On Search For The Store
  11. jared8783
    May 13, 2009
    216
    here you go old surfer
    Search Results
    you will see a spring and the tensioner on the top left on the search results
    i beleivve the tensioner assembly includes the spring though i could be wrong
    and I gotta say Tinsmith that is the first time I have seen a velocity stack on such a small engine
    #11 jared8783, Jun 22, 2010
