We have ordered a 80 2 stroke kit for my wife, but have yet to get a bike. She wants something that is easy to get on [low]. The kit says it is for a 26" weel, so if we went with a 24" weel would we need another sproket?
Except for a friction drive, which drives the outside diameter of the wheel at a certain speed (not rpm as a sprocket drive does) which would be friction wheel RPM multiplied by it's circumference. So the tire tread tavels a certain feet per second,not revolutions per second. And since the tread is connected to the ground, it then travels at the same feet per second.The rear wheel size does matter...a little, a 24" wheel will have a slightly lower overall speed at any given rpm than a 26".
Like Big Joe said: It won't make that much of a diffrence but the up side is she'll have better low end torque.The rear wheel size does matter...a little, a 24" wheel will have a slightly lower overall speed at any given rpm than a 26".
But the only thing to increase/decrease bike speed on friction drive is to change the drive wheel size, not the driven wheel size.Like Big Joe said: It won't make that much of a diffrence but the up side is she'll have better low end torque.
You're right too! It started out as a sprocket question, and somehow I ping-ponged into friction drive...my fault!My mistake. I didn't read the whole thread. I thought the discussion was about sprockets. You are correct that on friction drives, the diameter of the spindle determines the speed.
