E eisle89 New Member Jun 16, 2008 101 0 0 67 El Paso, Texas Jun 16, 2008 #1 I'm trying to use a 72 spoke wheel and mount the 9 bolt sprocket that comes with the Chinese motors. Is there ANY way ??? TIA
misteright1_99 New Member Mar 21, 2008 716 0 0 Treasure Coast, Florida Jun 16, 2008 #2 Sure any number that is divisible by 9 should work......
deacon minor bike philosopher Jan 15, 2008 8,117 3 0 north carolina Jun 16, 2008 #3 you might have to persuade it a bit.
RedB66 Active Member Dec 28, 2007 1,023 1 38 Sunshine State Jun 16, 2008 #4 It depends on the hub...it is enlarged you may have to force the bolts through.
E eisle89 New Member Jun 16, 2008 101 0 0 67 El Paso, Texas Jun 16, 2008 #5 But I don't want contact with the spokes correct ??? Maybe smaller diameter Grade 8 bolts ?? I wish i could get a blank sprocket somewhere so I can drill my own but haven't seen any.
Andyinchville1 Manufacturer/Dealer Dec 26, 2007 502 1 18 Scottsville, VA Jun 17, 2008 #6 HI eisle... We can make you a sprocket without mounting holes if you'd like... Andrew
E eisle89 New Member Jun 16, 2008 101 0 0 67 El Paso, Texas Jun 17, 2008 #7 Andyinchville1 said: HI eisle... We can make you a sprocket without mounting holes if you'd like... Andrew Click to expand... Thank you Andrew, I'll take you up on that once I get the holes measured out.
