E eisle89 New Member Jun 16, 2008 #1 I'm trying to use a 72 spoke wheel and mount the 9 bolt sprocket that comes with the Chinese motors. Is there ANY way ??? TIA
RedB66 Active Member Jun 16, 2008 #4 It depends on the hub...it is enlarged you may have to force the bolts through.
E eisle89 New Member Jun 16, 2008 #5 But I don't want contact with the spokes correct ??? Maybe smaller diameter Grade 8 bolts ?? I wish i could get a blank sprocket somewhere so I can drill my own but haven't seen any.
Andyinchville1 Manufacturer/Dealer Jun 17, 2008 #6 HI eisle... We can make you a sprocket without mounting holes if you'd like... Andrew
E eisle89 New Member Jun 17, 2008 #7 Andyinchville1 said: HI eisle... We can make you a sprocket without mounting holes if you'd like... Andrew Click to expand... Thank you Andrew, I'll take you up on that once I get the holes measured out.
