I fail to understand this.
from the magnecore site:
"FOR USE ON RACING VEHICLES THAT USE HIGH-OUTPUT IGNITIONS AND REQUIRE EMI SUPPRESSION"
also:
"Magnecor Solid Wire Conductor 7mm Wires
Magnecor has always provided 7mm tin plated stranded copper wire conductor wires for restorations and industrial applications. The cable used features an EPDM insulator covered with a silicone rubber jacket. The cable only can be supplied in bulk on reels containing up to 10,000 feet, although there is no minimum order required for the cable."
these appear to be two diff types of wire with solid core not sold in useful quantities - neither looks useful for our LOW-OUTPUT ign systems
I don't think you understand what you're reading. You can buy any length wire from them, and they will also make any custom length wire for you at no extra cost.
High output, or low output doesn't really matter to us. What a china girl needs is a low resistance solid core wire. You can get that kind of wire from a lot of places, but it won't be RF suppression wire. If you need solid core wires, but also RF suppression these are the best wires for that.
What these wires are designed for are vehicles with electronic ignitions that need suppressor wires to keep the RF from killing the ignition module, like Harley's for instance. Typically the only kind of wire you could use would be crappy carbon core suppression wire like you find at most auto supply stores. This type of wire is less desirable for a china girl because it's higher resistance than solid core wire that comes stock on china girls.
The reason you don't want high resistance wire is because it increases the current demand on the weak china girl magneto which can cause the windings to go poop dog
