ZDDP is not completely disappearing just reduced in API SM oils. But that's off the track.
HT's will run on most any oil. Additized engine oil will eventually foul your plug. My only point really.
Your head is loose? Needs proper torqueing.
Here's what I think is happening... The more oil in the gas, the less gas is in the mix. (More oil = leaner fuel/air mix.)
Freewheeler, I think re-jetting your carb (smaller) will make your bike run better with a normal gas/oil mix.![]()
Holy cow! I musta picked the right drill bit because I was flying today. My mount bolt came loose on the front which was because of vibration, but the vibration was because I was flying. For the first time, I actually was holding back on throttle to keep the vibes down. I have since fixed the loose front mount bolt and checked the plug. The plug was juicy black. I cleaned it again to get a another read, but rejetting seems good. I ride the same loop and when I hit the mega hill, it went into 2 stroke and stayed there for the first time. Bwwwaaahhhhhhh instead of pppppppppttttttt.
Still using 16:1 SAE30
Thats great FreeWheeler![]()
While I could very well be wrong here, I have experienced similar symptoms in the past with motorcycles. The problem was a plugged up exhaust. The idle was rough, throttle response was slow and the power was pathetic, but is still ran.
Early 70's Suzuki TX125 I think it was.
