replacing crankshaft seal
Discussion in 'Motorized Bicycle Trouble Shooting' started by sboricic123, Jul 10, 2013.
  1. sboricic123
    sboricic123 Member
    Apr 15, 2013
    168
    Is it an easy task replacing the crankshaft seal on a China girl 66cc?
    Are there things I should watch out for?
  2. 2door
    2door Moderator
    Staff Member
    16,301
    24
  3. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,428
    36
    also, pry upwards on the ends of the crank to be sure the mains aren't loose
    if loose, they need replacing as the seal won't work if the crank is moving up and down
  4. sboricic123
    sboricic123 Member
    Apr 15, 2013
    168
    I purchased a crankcase seal from a dealer that deals mostly with Skyhawk engines. I installed it but it doesn't seem to fit snug behind the magneto magdet. Is there a difference between the seals for each engine or could I possible have purchased the wrong seal?
  5. crassius
    Sep 30, 2012
    3,428
    36
    on most engines, the clutch side seal is wider than the magneto side
  6. sboricic123
    sboricic123 Member
    Apr 15, 2013
    168
  7. crassius
    Sep 30, 2012
    3,428
    36
    sorry, never heard of that store
    no info there about the seal and I also looked at a crank bearing, but no info there either except that the pic showed some kind of sealed bearing
    search around this board & you'll see a post somewhere about ordering seala as a pair
  8. 2door
    2door Moderator
    Staff Member
    16,301
    24
    I'm not suggesting one vendor over another but just linking this page to you so you can see a comparison between the thick and thin seals. http://www.pistonbikes.com/category-s/10.htm Most of our advertisers carry these seals.
    The thinner one goes behind the magneto rotor; the thicker one behind the primary gear on the right side.
  9. sboricic123
    sboricic123 Member
    Apr 15, 2013
    168
    2Door. Thanks for that link. To bad they don't ship to Canada. I'll have to Google and see what other shops there are. I may check a few small engine shops in my area to see if they might have one.
