I am trying to assemble the rag joint and none of the screws line up after going through the rag joint. We cant get any of the screws do line up! We are putting the rubber things in boiling water to loosen them up. Any other suggestions?
Here is one way....So I have had my bike for a few months now but I just recently noticed my sprocket is off center and my chain is really loose any ideas on how to re-center my sprocket?????
If the center hole in the sprocket isn't OVER the hub on the bike..they never will line up and stop from wobbling. Are you working on a coaster brake set up?ok, so i got the sprocket on but noticed that after the thing it tightened, i noticed it was wobbling side to side. The problem is it is tight enough already, so i dont think it will go any more.
You will need to cut the bearing cap, which I don't do or enlarge the center hole.the sprocket is around the hub and fit perfectly. I just need to know how to make it true.
EDIT: Yes i am working on a coaster brake setup. Firmstrong urban with Hi-Stop brake hub. I did order a front hand brake btw.
