Hello there, I am new to gasoline powered bikes, Years ago i built a Lithium brushless, but got out of it.
I just want to cruse on a motorized bike, simply and not get too involved. Speed doesn't matter just a little engine roar, ill be pedaling the whole time as well with it. System must be 4 stroke, i dig the sound and intend to use regular gas.
I will try my best to be clear and not redundant i don't want to waste anyone's time, and before i begin i sincerely thank you for taking a time out to help a total newb/novice.
I have decided i want a simple friction drive set up, I have a few bikes and will most likely ping pong to them.
I dig the friction set up and cant wait to set one up.
I noticed MANY friction kits on Staton-inc.com and i am eager to buy one
Having said that i am looking for a drop in motor solution, I would like the motor to be cheap to outright replace, and also be able to get parts like clutches, and carbs for it
Would that 79cc Predator motor drop into one of those friction transmissions? (they seem to have a lot of models with various sized clutch bells)
I don't see a way of verifying it in a spec sheet.
It also appears that the Predator does not come with a clutch, i sadly do not know what clutch to buy that would connect to the shaft.
I kinda wish i could just add the parts to cart and charge my credit card and then begin assembly, I have a lot on my plate right now in life, and don't have the time to do serious modding welding and fab work.
I know about the:
https://www.amazon.com/Adapter-Pulley-Reducer-Sleeve-Bushing/dp/B01FDZWFFE
to increase the shaft diameter, but...i still dont know what clutch would fit on it, kinda lost.
If the predator is just not the best option, Id like to know, perhaps there are other Motors out there that are simple drop in solutions and are reliable for many miles?
the predator is VERY cheap...a huge plus
Anyway i dont want this initial post to go on too long, i appreciate your time and look forward to hearing and learning from you.
I know about the:
