Possible Motorized Trike?
Dude, If all ya want is to get around the next burning man, Then just get an el cheapo electric scooter. I've seen several on craigslist.
And I didn't even try very hard to find them.
fatdaddy.
It looks like your trike has gears, is that correct?
If so then you might like this setup, I've built 3 like this and kept this last one for a shop bike for parts runs.
cyclone-e-bikes motor with freewheel sprocket mounted to a standard freewheel bottom bracket assembly for sick bike parts as the motor is high enough to not need wider crank arms.
I put the battery, controller and charger in that black metal box in back, then mounted the basket to the top but you could mount a back facing chair just as easy.
The trike pictured has a 6-speed derailleur, it will putt along at 1 MPH and top out at 25MPH on flat pavement, the important part is putt putt along and very low speeds without bogging which would be hard for any gas powered direct drive.
The motor, controller and bottom bracket are about $400, the expensive part is the battery.
I have a $600 overkill battery for your needs in mine but at the speeds and distance you will be riding even in the Nevada desert I'd bet it would last you the whole week without a charge.
My server is down today so the pics don't display today but the parts specs are in this topic here http://motorbicycling.com/showthread.php?t=44144
Regardless of the motor choice you make you really should flip the trike over, clean and lube the wheels and check the drive train, it looks pretty 'rustic' if you know what I mean ;-}
Good luck with the project and drop me an E if you have questions about the parts.
No thread on it SB, Just a lot of pics. I called it Widowmaker. I built it before I was a forum member. When I first got it together I had it geared all wrong. A PITA to get started, but once the clutch quit slipping at about 30mph and the engine caught up the thing was hitting 60mph or better. Well, Thats as fast as I wanted to take it anyway, I still had throttle left. I re-geared it (try to make sure nobody would die on it,) and sold it. That's one I wish I woulda kept. A BLAST to ride and it got A LOT of attention.
And (BA ALPHA, Welcome to the forum,) An engine on the front wheel causes all kinds of steering and balance problems. An electric front wheel drive hub would work great, but a heavy engine, even just a few pounds, on the front wheel, throws off your steering and control abilities. Thats why the front drive Bike Bug kit isn't very popular.
http://www.bikebug.net/all_models.html
fatdaddy.
I've had front friction drive and front electric hub, not on the same bikes. There is SOME truth about your opinion about steering and balance issues, but only @ walking speed on a bicycle, but not a trike. When parked, you'd need to strap the right-side handlebar grip to the top tube to keep the fork from cocking, thus tipping the bike (but not a trike) over.
Once the bike is moving faster then walking speed, there are no steering or balance issues.
A front hub works great, no steering or balance issues.
Front friction drive is the fastest, simplest install, unless you have a suspension fork.
Yer probably right 5-7, But the last one I rode with a front mount engine just felt heavy and sluggish in the steering dept. To each his own.
fatdaddy.
