I bought a "modified piston and ported cyl" from a vender here and was suprised that the piston was cut all the way around. Also the "ramps" on the piston were also shaved all the way around too. I figured they know what they are doing so I installed the piston and cyl. Took it for a ride, Way slow, no bottom end at all. Puled the cyl and replaced it with mystock cyl. Ran quite a bit better but still no bottom end. I was also getting a bunch of oil leaking around my exhaust gasket. Today I decided to pull the pipe and look inside. Yep piston at TDC is 2mm above exh port.
