Oil-Gas ratios
Discussion in 'Motorized Bicycle General Discussion' started by Farthom, Jun 4, 2010.
  1. Farthom
    Farthom New Member
    May 16, 2010
    51
    Alright, I have a grubee skyhawk 66cc angle fire engine, and the bikeberry.com manual that came with it says to use between 16:1 and 20:1 for engine break in, and between 20:1 and 25:1 thereafter. After reading a bunch of posts, I have seen lots of people recommending and/or using mixtures such as 25:1 for break in and 35:1 after. One post spoke of a mixture as lean as 40:1
    I have been using about 16:1 for break in, and am nearly complete. After I have used up this tank, I would like to know what mixtures I should/could be using. I'm somewhat new to this game, and don't know all the variables that come into play here. What I do know, is that the quality of oil matters. I asked the sales rep in an auto store for a good quality full synthetic oil, and purchased the following:
    PJ1 Goldfire Pro
    High RPM 2T 2-stroke oil
    50:1 synthetic blend
    This oil was somewhat expensive, so I'm pretty sure its a good oil. I don't know what "2t" means, or what 50:1 blend means. Can someone fill me in?
    Also can some of the veterans on here give me a yay or nay, on this motor oil, and some tips on what ratios I could be using?
    Thanks a bunch!
    Farthom
  2. Pablo
    Pablo Master Bike Builder & Forum Sponsor
    Dec 28, 2007
    3,652
    a) it depends on the oil, indeed there are some oils that work at 100:1
    b) really no need for 16:1 during break in. I never have run more oil than 24:1, ever
    c) never heard of that oil, but they are saying it can be run at 50:1
    Mix up 25:1, and ride the bike and don't stress about it.
  3. Farthom
    Farthom New Member
    May 16, 2010
    51
    How much can oil mixture affect engine performance?
  4. nolan_speed
    nolan_speed New Member
    May 31, 2010
    30
    I'm pretty new to these engines but I've been running mine at 25:1 with Shell Natilus oil (that's what they had at the nearest gas station) and so far it's working fine. I figure that at 25:1 there is plenty of oil (most quality engines run 50:1) so the type probably doesn't matter nearly as much as if you're running an engine at the leaner ratios.
    If you run a two stroke without enough oil it'll make more power for a little while but you'll burn it up and the motor will be toast. If you run it with too much oil it'll make a little less power and it'll foul the spark plug. It's obviously better to err on the rich side.
    Maybe with your synthetic oil you could try splitting the difference between 25:1 and 50:1 and go for 32:1 or something? With less oil you'll make more power but you don't want to go with too little.
  5. Farthom
    Farthom New Member
    May 16, 2010
    51
    What exactly is fouling a spark plug, and how can I tell whether I have done it or not?
  6. nolan_speed
    May 31, 2010
    30
    A fouled plug is one that is covered in oil and created a weak spark or no spark at all. When your plug is fouled the engine will be hard to start and will run like crap, especially at lower RPM, sometimes running the engine really hard will burn off the plug and it'll start working well again.
    If running it hard dosn't work, remove the plug and you'll notice that it's black an oily and will need to be cleaned or replaced.
  7. JG88cc
    JG88cc New Member
    Sep 22, 2010
    15
    It would be a great idea to switch to a spark plus with a resistor at the end. They are made to prevent fouled spark plugs. I just bought a NGK BPRGKS.
    Not saying you shouldn't carefully mix your gas/oil (you really should). But its a good idea.
  8. Pablo
    Dec 28, 2007
    3,652
    Not sure who told you that, but it's not true.
  9. Shobiz1492
    Shobiz1492 New Member
    Feb 13, 2013
    25
  10. Bikeguy Joe
    Jan 8, 2008
    11,529
    Looks like a generic two stroke oil for air cooled engines.
    What is the recommended ratio on the bottle?
  11. Shobiz1492
    Feb 13, 2013
    25
    it says up yo 50:1
