Hey everyone, this is my first post so please bear with me here. Alright so let me start by listing what I'm working with: (I underlined the most important stuff)
Elevation: Sea level
Terrain: All flat other than trails which rarely have hills of more that 6 feet gain in elevation at 40 degree angles
Current and recent temps: 70's to high 80's (F)
Me: 5'11" 155lbs
Bike: Old (steel frame?) men's hard-tail MTB 21-speed with straight handlebars & cloud 9 seat and 26" wheels with off-road tires.
Engine (kit): PK80 (66cc 2-Stroke Angle Fire Flying Horse engine with NT carb and stock exhaust) ordered from Bikeberry via Amazon. Engine is broken in. I've had it for about 3 months.
Mounting: Standard/Stock hardware with NO rubber or anything between the frame and the engine mounts
Fuel: BP Ethanol Free (I will check the octane later, sorry)
Oil: Promix 2-cycle low smoke, fuel stabilizing, synthetic blend
Mix ratio: 40:1
Sprocket size: 44t, 415 chain, stock chain tensioner, stock rag joint sprocket mount
General Modifications: Mousepad on clutch cover and magneto cover etc, Plastidip on inside of clutch cover with 3 clutch cover gaskets as spacers, Silicone sealant around magneto cover seam to block water from getting in, dual brake lever
Engine/Performance Modifications: NKG B6HS Plug, Dellorto #64 main jet from SBP, and finally a really ghetto but non-restrictive -(I tested it to make sure but I could be wrong) - air intake mod where I hooked a short 8 inch garden hose diameter piece of tube to the intake on the air filter and ran it up under the seat to quiet the intake noise (also to keep dirt from shooting up into and through the stock air filter while trail riding)
Primary uses: Trail riding and riding around town (I ride usually under 20 miles)
Alright so I probably forgot a bunch of stuff so I'll gladly add any missing info and pictures as needed.
OK! so here's my issue:
Everything was bone stock on the bike up until a month ago, and I was running it at a top speed on flat asphalt WOT and no wind at about 26 or 27mph. Minimal Vibrations. Some 4 stroking.
After adding that new NKG plug and air intake hose thing it ran the same. 26mph WOT Minimal Vibrations. Some 4 stroking.
About a week or two ago, I was reading on here that the stock NT jets are almost always too rich at about a #68 or #70 (correct me if I am wrong). I wanted to solder mine and re drill it myself but was short on free time so I bought a Dellorto #64 jet from SBP. So I switched the jet and here are the results:
I immediately noticed the exhaust smelled a little different (or maybe I just inhaled too much gas fumes haha)
The bike seemed to rev much higher as I tested the throttle with the clutch pulled in. The bike vibrates a ton more now and was enough to break my 2800 lumen headlight =( and cause my gas cap to blow off.
the handlebars rattle much more now.
When riding it: I seem to have lost about half of my low end torque but the bike seems to 4 stroke a little less or at least at different and less throttle positions.
Now keeping in mind all I did was swap the jet, the bike now does 35!!!
So now I being a noob am kinda just sitting here thinking what the ****...
My goal is to find the right balance where I still have my low end for trail riding but can get going a little quicker than 25. I plan to put an expansion chamber on it, port it, save up for a shift kit, and etc but I want to start off on the right foot so I know the best my little engine can offer (i.e. getting her running her best) before I go bolting on new parts.
So my question to yall is, what have I done and what should I do with the jet size?
Thanks a ton in advance
-Noob
Me: 5'11" 155lbs
Mix ratio: 40:1
-Noob
