Noises at 20 mph- help
Horacio
Ok so I have searched the topic, and couldn't find a solution, when riding my bike, it will run fine from 0-19 but as soon as it hits 20 the engine begins to make a noise, I am not sure if it is the engine, or the chain scraping against the clutch cover, (inside of the cover is grinded to ****, but that was from before due to chain alignment, I THINK I fixed it.)
Whenever I go down hills i have to hold in the clutch for the whole hill, and even on flat land (when i find some) I have to hit the brakes and hold the clutch until it slows under 20. Any suggestions, let me know what pictures would be helpful. Thank you.flg.
Here is a link to the video of when it hits 20
http://www.youtube.com/watch?v=yo0PE8BkALs
I would suspect that over there in Korea, folks are accustomed to being creative and working with what they have available???
Here's a bottom of the barrel suggestion, if you wish...
I have rarely seen a one-piece crank on a bicycle that did not have excess grease packed into the center of the BB. Pull a crank from one of those bikes and grab a bit of that on the end of your finger and force it down in the hole when the stay is removed, as R has said.
Another option??? I have never, ever, seen a front wheel spindle on an automobile that did not have extra grease globbed inside the hub, on a rwd car.
Same thing... grab a bit there.
Most cars have a glob under the grease cap for the front hub !
Any of those will provide far more than you will need for this application.
Good luck
rc
so i went to 3 mechanics, all of them spoke english, but wouldn't put grease on it, they said they will only put wd40. So i am just going to have to do it myself, but i need to be sure of where to put it, i should put it inside the sprocket correct? where the clutch bar goes?
Remove the cable stay... it is on top, between the sprocket on the LH side of the engine unit, and where the clutch is on the right side inside the large cover.
Remove that, and pack some grease down in there.
And if you do as some have said, pumping it in 'til it oozes out by the sprocket, there will shortly be grease all over everything, and the clutch may stop functioning. My guess.
I'm thinking about a teaspoon should resolve your problem if it is getting noisy.
Try that amount before deciding to put in more.
rc
I think the problem is an excessive amount of side play of your
chain. Do you have a chain tensioner on it to help the chain alignment?
It looks like the chain gets more violent side to side play the faster you
go. Try adjusting your roller adjuster and retighten your chaun.
well after the mechanics put wd40 on it it would sometimes get to 24 without making noises, but sometimes still at 20. i'm afraid if i tighten it it will cause the chain to break, cause that was my problem in the beggining, how tight is right?
I'll agree with that one!
Would have been better off pouring in a bit of 30wt engine oil, or better yet, 90wt gear oil.
rc
Well they are Korean mechanics, they are all about the same. I'll be back in the states by xmas, and hopefully things will be easier.
As a last resort, you could put a teaspoon of motor oil, like Rustycase said, into the clutch, and then tilt the bike from side to side so that the oil can flow over to both bearings and lubricate them somewhat.
why as a last resort? what could be the consequenses?
