New piston rings
Discussion in 'Motorized Bicycle General Discussion' started by fischer550, Apr 13, 2014.
  1. fischer550
    fischer550 Member
    Mar 24, 2014
    234
    I took my motor apart last week and accidentally broke a ring, so I put two new ones on. Do I have to re-start the break in process, or am I good to go? Thanks
  2. Kioshk
    Kioshk Active Member
    Oct 21, 2012
    1,153
    The rings WILL need some breaking in, but not as much as with a new jug, and even less so than with a brand new engine. Expect the rings/jug relationship to blossom into marriage in about 50-miles.
  3. Thunderhead289
    Thunderhead289 New Member
    Jul 2, 2013
    49
    rings have a hard time seating unless the cylinder has some crosshatching. im sure you will get by, and I would do the same, but that is how a ring job is done correctly
  4. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
    Old jug or not if I put new rings in I make me a flapper by cutting a slit in a 8-10" length of 3/8" wooden dowel rod and then I cut a 1" wide piece of 600 grit wet dry sandpaper fold it in half and slide the center of it into the slot in dowel rod and then chuck the dowel up in my cordless drill and use that to put a good cross hatch hone inside the jug, on these engines with a chromed bore the bore is much harder than the rings so you want the cross hatch to actually wear the ring into conforming with it and that is what makes for a good compression seal between rings and the jug/ cylinder wall.
    You are correct Thunderhead289
