Well guys...she is up and running, at least with the max torque for now. I will order another bully at the end of the month. But, it wasn't without a hiccup...probably like most men on here we are like little boys with new toys. You know that nice shiny billet aluminum rear sprocket I have? Not that way anymore. When I first received it, I bolted it up to my rear hub, hand tightened the bolts and checked for clearance issues...all was good....that was 3 months ago. I FORGOT TO TIGHTEN THEM! Needless to say the bolts worked loosed, threw the chain and it got stuck between the chainstay and sprocket. Chewed the sprocket up something good and twisted the chain up. Well, I had more chain and the sprocket did not get damaged besides cosmetics. I applied locktite to all bolts and torqued them down.
Rides like a champ, now! Lol... stupid mistake on my part and I will be reminded of it every time I look at the sprocket. I will try and clean it up somehow.
It is a little slow off the line because my gear ratio is off due to using the max torque, but it rides smooth. Once I get the bully, she should be top notch. Other than that, just little odds and ends that I eventually want to add on.
Remember folks, check, double check, and re-check. Might just save your life. I was lucky this time...
